주요 콘텐츠로 건너뛰기
How to Repair the Hinges on a Sofa Storage Compartment
필요한 것
  1. How to Repair the Hinges on a Sofa Storage Compartment, Hinges: 1 단계, 이미지 1/2 How to Repair the Hinges on a Sofa Storage Compartment, Hinges: 1 단계, 이미지 2/2
    • Partially remove the inside fabric to access screw holes.
    • If the fabric is stapled down, you can use the Phillips screwdriver to loosen the staples. In this case, the fabric was already coming off so it was easy to pull back by hand.
  2. How to Repair the Hinges on a Sofa Storage Compartment: 2 단계, 이미지 1/2 How to Repair the Hinges on a Sofa Storage Compartment: 2 단계, 이미지 2/2
    • Apply glue to the match stick and insert it into the screw holes.
    • Depending on the size of the hole, you may need more than 1 match stick for each hole. Toothpicks will also work in place of a match stick.
  3. How to Repair the Hinges on a Sofa Storage Compartment: 3 단계, 이미지 1/2 How to Repair the Hinges on a Sofa Storage Compartment: 3 단계, 이미지 2/2
    • Break off the end of the match sticks and use a hammer to secure it in the holes
    • A gentle tap with the hammer is all you need to set the stick into the hole.
  4. How to Repair the Hinges on a Sofa Storage Compartment: 4 단계, 이미지 1/1
    • Use the staple gun to staple the inside fabric. Allow the glued match sticks to dry for approximately 5 minutes before doing the next step.
  5. How to Repair the Hinges on a Sofa Storage Compartment: 5 단계, 이미지 1/2 How to Repair the Hinges on a Sofa Storage Compartment: 5 단계, 이미지 2/2
    • Use a Phillips screwdriver to attach each hinge to the cover of the storage compartment with two ¾-inch Flat-Head Wood screws #9.
  6. How to Repair the Hinges on a Sofa Storage Compartment: 6 단계, 이미지 1/2 How to Repair the Hinges on a Sofa Storage Compartment: 6 단계, 이미지 2/2
    • Use a Phillips screwdriver to attach each hinge to the base of the storage compartment with four ¾-inch Flat-Head Wood screws #9.
  7. How to Repair the Hinges on a Sofa Storage Compartment: 7 단계, 이미지 1/1
    • Here is the Storage Compartment all back together and good as new!
결론
After following this fast fix guide, the hinges should be tightly secured and storage compartment is fixed.
Karen Walters
회원 가입일: 06/28/21
145 평판
안내서 1개 작성함
York University, Team S29-G29, Melo-Thaiss Summer 2021 York University, Team S29-G29, Melo-Thaiss Summer 2021 회원
YORK-MELO-THAISS-SU21S29G29
1 회원
안내서 1개 작성하였습니다
0 댓글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 8
30일 전: 60
전체 시간: 636
