주요 콘텐츠로 건너뛰기
How to Repair the Jump Ring on a Mask Holder
필요한 것
  1. How to Repair the Jump Ring on a Mask Holder, How to Repair the Jump Ring on a Mask Holder: 1 단계, 이미지 1개 중 1개
    • Remove the broken or opened jump ring from your mask holder.
  2. How to Repair the Jump Ring on a Mask Holder: 2 단계, 이미지 1개 중 1개
    • Hold needle nose pliers with one hand and the jump ring in the other.
    • Make sure you have good light so you can see clearly.
  3. How to Repair the Jump Ring on a Mask Holder: 3 단계, 이미지 2개 중 1개 How to Repair the Jump Ring on a Mask Holder: 3 단계, 이미지 2개 중 2개
    • Use the pliers to open the jump ring carefully.
  4. How to Repair the Jump Ring on a Mask Holder: 4 단계, 이미지 1개 중 1개
    • Reattach the chain to the jump ring.
  5. How to Repair the Jump Ring on a Mask Holder: 5 단계, 이미지 1개 중 1개
    • Use the pliers to close the jump ring.
  6. How to Repair the Jump Ring on a Mask Holder: 6 단계, 이미지 2개 중 1개 How to Repair the Jump Ring on a Mask Holder: 6 단계, 이미지 2개 중 2개
    • Make sure the ring is closed tightly so the mask holder stays secure.
결승점
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 5
전체 시간: 458
