주요 콘텐츠로 건너뛰기
How to Repair the Kohler Step Trash Bin 6L/1.6 Gal
필요한 것
  1. How to Repair the Kohler Step Trash Bin 6L/1.6 Gal, How to Repair the Kohler Step Trash Bin 6L/1.6 Gal: 1 단계, 이미지 1/2 How to Repair the Kohler Step Trash Bin 6L/1.6 Gal, How to Repair the Kohler Step Trash Bin 6L/1.6 Gal: 1 단계, 이미지 2/2
    • Open the lid of the trash bin.
    • Use a Phillips #2 screwdriver to remove the two 15.0 mm screws attaching the lid to the hinge of the bin.
  2. How to Repair the Kohler Step Trash Bin 6L/1.6 Gal: 2 단계, 이미지 1/1
    • Remove the lid.
    • Carefully unhook the black metal hook from the attached lid supporters at the back by shifting the supporters to the left.
  3. How to Repair the Kohler Step Trash Bin 6L/1.6 Gal: 3 단계, 이미지 1/1
    • Pull out the inner layer of the trash bin.
  4. How to Repair the Kohler Step Trash Bin 6L/1.6 Gal: 4 단계, 이미지 1/2 How to Repair the Kohler Step Trash Bin 6L/1.6 Gal: 4 단계, 이미지 2/2
    • Carefully secure and connect the step pedal, metal rod with the hook metal rod at the bottom of the trash bin.
  5. How to Repair the Kohler Step Trash Bin 6L/1.6 Gal: 5 단계, 이미지 1/2 How to Repair the Kohler Step Trash Bin 6L/1.6 Gal: 5 단계, 이미지 2/2
    • Push back the upper hook on the lid supporters.
    • Then place the lid back on top of the lid supporter.
  6. How to Repair the Kohler Step Trash Bin 6L/1.6 Gal: 6 단계, 이미지 1/1
    • Replace the two 15.0 mm screws of the lid of the trash bin near the hinge, with the Phillips #2 screwdriver.
결론
다른 3명이 해당 안내서를 완성하였습니다.
David Huang
회원 가입일: 02/09/23
193 평판
안내서 1개 작성함
York University, Team M-11, Allen Winter 2023 York University, Team M-11, Allen Winter 2023 회원
YORK-ALLEN-W23SMG11
1 회원
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 16
30일 전: 65
전체 시간: 964
