주요 콘텐츠로 건너뛰기
How to Repair the Lining of a Leather Wallet
필요한 것
  1. How to Repair the Lining of a Leather Wallet, Lining: 1 단계, 이미지 1개 중 1개
    • Use scissors to cut any hanging threads.
  2. How to Repair the Lining of a Leather Wallet: 2 단계, 이미지 2개 중 1개 How to Repair the Lining of a Leather Wallet: 2 단계, 이미지 2개 중 2개
    • Flip the entire wallet inside out.
  3. How to Repair the Lining of a Leather Wallet: 3 단계, 이미지 3개 중 1개 How to Repair the Lining of a Leather Wallet: 3 단계, 이미지 3개 중 2개 How to Repair the Lining of a Leather Wallet: 3 단계, 이미지 3개 중 3개
    • Pin the cloth into place with safety pins.
    • Make sure not to poke through the leather. If there is no way to do this without damaging the leather, skip this step.
  4. How to Repair the Lining of a Leather Wallet: 4 단계, 이미지 2개 중 1개 How to Repair the Lining of a Leather Wallet: 4 단계, 이미지 2개 중 2개
    • Cut about a centimeter off the end of the sewing thread to get rid of any fraying.
    • Guide the thread through the hole at the top of the needle.
    • Pull about 20.32-30.48 cm of the thread through to prevent the thread from slipping out while sewing.
    • If it is too difficult to get the thread through the hole, wet the end of the thread and roll it between two fingers to create a pointed end and try again.
    • Cut about 0.91 meters of thread from the spool.
  5. How to Repair the Lining of a Leather Wallet: 5 단계, 이미지 3개 중 1개 How to Repair the Lining of a Leather Wallet: 5 단계, 이미지 3개 중 2개 How to Repair the Lining of a Leather Wallet: 5 단계, 이미지 3개 중 3개
    • Starting at the beginning of the tear, sew thread from the inside of the wallet to the outside.
    • Sew thread back from the outside of the wallet to the inside of the wallet.
    • Tie the threads together 2 or 3 times.
    • Leave very little gap between first and second stitch hole.
  6. How to Repair the Lining of a Leather Wallet: 6 단계, 이미지 2개 중 1개 How to Repair the Lining of a Leather Wallet: 6 단계, 이미지 2개 중 2개
    • Locate holes in the leather from existing stitches and sew through them, making sure to avoid damaging it.
    • Perform a standard backstitch: skip one of the holes and sew from the inside of the wallet to the outside through second hole, then sew from the outside to the inside through the hole that was skipped.
    • Repeat until the lining is completely reattached.
  7. How to Repair the Lining of a Leather Wallet: 7 단계, 이미지 2개 중 1개 How to Repair the Lining of a Leather Wallet: 7 단계, 이미지 2개 중 2개
    • At the end of the tear, sew from the inside of the wallet to the outside, leaving a sizable loop of thread.
    • Sew thread back from the outside of the wallet to the inside, leaving very little space between stitches.
  8. How to Repair the Lining of a Leather Wallet: 8 단계, 이미지 2개 중 1개 How to Repair the Lining of a Leather Wallet: 8 단계, 이미지 2개 중 2개
    • Tie the loop and the hanging thread together 2 or 3 times.
  9. How to Repair the Lining of a Leather Wallet: 9 단계, 이미지 2개 중 1개 How to Repair the Lining of a Leather Wallet: 9 단계, 이미지 2개 중 2개
    • Cut any extra thread and remove the safety pins.
  10. How to Repair the Lining of a Leather Wallet: 10 단계, 이미지 2개 중 1개 How to Repair the Lining of a Leather Wallet: 10 단계, 이미지 2개 중 2개
    • Flip the wallet back so the lining is on the inside.
    • The lining should be securely attached to the interior of the wallet!
결승점
작성자
2다른 기여자 명과 함께
Riya
회원 가입일: 01/26/23
181 평판
안내서 1개를 작성함
UC Davis, Team 2-6, Morris Winter 2023 UC Davis, Team 2-6, Morris Winter 2023 회원
UCD-MORRIS-W23S2G6
2 회원들
안내서 3개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 20
지난 30일: 106
전체 시간: 2,412
