주요 콘텐츠로 건너뛰기
How to Repair the Sole of a Heeled Shoe
필요한 것
  1. How to Repair the Sole of a Heeled Shoe, How to Repair the Sole of a Heeled Shoe: 1 단계, 이미지 1개 중 1개
    • Use sanitizing wipes to clean any debris in the tear of the sole.
  2. How to Repair the Sole of a Heeled Shoe: 2 단계, 이미지 1개 중 1개
    • Carefully pull the sole away from the shoe, making sure not to widen the tear or cause excessive deformation.
  3. How to Repair the Sole of a Heeled Shoe: 3 단계, 이미지 1개 중 1개
    • Apply enough glue in the space so that an even layer is able to form between the shoe and sole when pressed together. Make sure to apply some along the inside seam.
  4. How to Repair the Sole of a Heeled Shoe: 4 단계, 이미지 3개 중 1개 How to Repair the Sole of a Heeled Shoe: 4 단계, 이미지 3개 중 2개 How to Repair the Sole of a Heeled Shoe: 4 단계, 이미지 3개 중 3개
    • Apply pressure on the sole to secure the seal and wipe away any excess glue.
  5. How to Repair the Sole of a Heeled Shoe: 5 단계, 이미지 2개 중 1개 How to Repair the Sole of a Heeled Shoe: 5 단계, 이미지 2개 중 2개
    • Use rubber bands to secure the sole to the shoe while it dries. This will ensure a firm seal.
  6. How to Repair the Sole of a Heeled Shoe: 6 단계, 이미지 1개 중 1개
    • Allow the glue to dry in the secured shoe for 72 hours.
결론
Enjoy the newfound longevity of your shoe!
다른 2명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Sarah A.P.
회원 가입일: 09/19/22
163 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 9
지난 30일: 24
전체 시간: 848
