주요 콘텐츠로 건너뛰기
How to Repair the Sparker on a Merlion Mini Torch
필요한 것
  1. How to Repair the Sparker on a Merlion Mini Torch, How to Repair the Sparker on a Merlion Mini Torch: 1 단계, 이미지 1/3 How to Repair the Sparker on a Merlion Mini Torch, How to Repair the Sparker on a Merlion Mini Torch: 1 단계, 이미지 2/3 How to Repair the Sparker on a Merlion Mini Torch, How to Repair the Sparker on a Merlion Mini Torch: 1 단계, 이미지 3/3
    • Use the screwdriver to remove all the 1.2 mm Phillips #1 countersunk screws from the torch.
  2. How to Repair the Sparker on a Merlion Mini Torch: 2 단계, 이미지 1/2 How to Repair the Sparker on a Merlion Mini Torch: 2 단계, 이미지 2/2
    • Open up the torch.
    • Set aside the empty side of the torch.
  3. How to Repair the Sparker on a Merlion Mini Torch: 3 단계, 이미지 1/3 How to Repair the Sparker on a Merlion Mini Torch: 3 단계, 이미지 2/3 How to Repair the Sparker on a Merlion Mini Torch: 3 단계, 이미지 3/3
    • Pull the handle down as if you were to use the torch.
    • You will see one of the parts inside spark. This is the sparker.
    • Now gently remove the handle and set it aside.
  4. How to Repair the Sparker on a Merlion Mini Torch: 4 단계, 이미지 1/2 How to Repair the Sparker on a Merlion Mini Torch: 4 단계, 이미지 2/2
    • Grab your pliers and GENTLY tug the sparker towards the Merlion head until it is extended about a centimeter.
  5. How to Repair the Sparker on a Merlion Mini Torch: 5 단계, 이미지 1/2 How to Repair the Sparker on a Merlion Mini Torch: 5 단계, 이미지 2/2
    • Gently bend the sparker until it is positioned near the opening of the Merlion's mouth.
  6. How to Repair the Sparker on a Merlion Mini Torch: 6 단계, 이미지 1/3 How to Repair the Sparker on a Merlion Mini Torch: 6 단계, 이미지 2/3 How to Repair the Sparker on a Merlion Mini Torch: 6 단계, 이미지 3/3
    • Grab the tube and gently bend it so it faces the opening of the Merlion's mouth.
    • Put the handle back on the torch.
  7. How to Repair the Sparker on a Merlion Mini Torch: 7 단계, 이미지 1/3 How to Repair the Sparker on a Merlion Mini Torch: 7 단계, 이미지 2/3 How to Repair the Sparker on a Merlion Mini Torch: 7 단계, 이미지 3/3
    • Take the empty half of the torch and place it over the other half.
  8. How to Repair the Sparker on a Merlion Mini Torch: 8 단계, 이미지 1/3 How to Repair the Sparker on a Merlion Mini Torch: 8 단계, 이미지 2/3 How to Repair the Sparker on a Merlion Mini Torch: 8 단계, 이미지 3/3
    • Use the screwdriver to put the screws back in the torch.
  9. How to Repair the Sparker on a Merlion Mini Torch: 9 단계, 이미지 1/2 How to Repair the Sparker on a Merlion Mini Torch: 9 단계, 이미지 2/2
    • Hold the torch upside down and position the butane above the torch's hole.
    • Gently press down for five seconds.
결론
Congrats! Now you can use your Merlion torch again.
다른 3명이 해당 안내서를 완성하였습니다.
Neel Kogali
회원 가입일: 09/29/15
200 평판
안내서 1개 작성함
Cal Poly, Team 14-3, Green Fall 2015 Cal Poly, Team 14-3, Green Fall 2015 회원
CPSU-GREEN-F15S14G3
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 8
30일 전: 17
전체 시간: 7,548
