주요 콘텐츠로 건너뛰기
How to Repair the Tip of a Fishing Rod
필요한 것
  1. How to Repair the Tip of a Fishing Rod, Tip of a Fishing Rod: 1 단계, 이미지 1/3 How to Repair the Tip of a Fishing Rod, Tip of a Fishing Rod: 1 단계, 이미지 2/3 How to Repair the Tip of a Fishing Rod, Tip of a Fishing Rod: 1 단계, 이미지 3/3
    • Determine what tip fits the fishing rod the best.
    • A tight fit is preferable and will have the best outcome for the repair.
  2. How to Repair the Tip of a Fishing Rod: 2 단계, 이미지 1/3 How to Repair the Tip of a Fishing Rod: 2 단계, 이미지 2/3 How to Repair the Tip of a Fishing Rod: 2 단계, 이미지 3/3
    • Melt the tip of the glue stick with a lighter.
    • Use a paper towel underneath the area you melt the glue because it can melt very quickly and drip on the surface where you are working.
    • Take the necessary precautions when applying heat to the glue stick because an open flame and hot glue are involved and can burn skin and other things.
  3. How to Repair the Tip of a Fishing Rod: 3 단계, 이미지 1/3 How to Repair the Tip of a Fishing Rod: 3 단계, 이미지 2/3 How to Repair the Tip of a Fishing Rod: 3 단계, 이미지 3/3
    • Apply the melted glue immediately around the top of the rod.
  4. How to Repair the Tip of a Fishing Rod: 4 단계, 이미지 1/3 How to Repair the Tip of a Fishing Rod: 4 단계, 이미지 2/3 How to Repair the Tip of a Fishing Rod: 4 단계, 이미지 3/3
    • Immediately apply the melted glue around the tip you are going to use.
    • If the glue stick cooled, apply heat again to make it useful.
  5. How to Repair the Tip of a Fishing Rod: 5 단계, 이미지 1/3 How to Repair the Tip of a Fishing Rod: 5 단계, 이미지 2/3 How to Repair the Tip of a Fishing Rod: 5 단계, 이미지 3/3
    • Put the tip on top on the rod immediately after doing steps 3 and 4.
    • Be sure to align the tip with the other guides on the rod.
    • If between steps the glue dried on either part, reapply heat to soften the glue so the parts fit together.
  6. How to Repair the Tip of a Fishing Rod: 6 단계, 이미지 1/1
    • Allow the glue to cool.
  7. How to Repair the Tip of a Fishing Rod: 7 단계, 이미지 1/3 How to Repair the Tip of a Fishing Rod: 7 단계, 이미지 2/3 How to Repair the Tip of a Fishing Rod: 7 단계, 이미지 3/3
    • Apply some heat to the fishing rod and remove the excess glue with a paper towel.
    • Let it cool down again.
결론
When you put the tip on the rod with the glue, verify that it is align with the other guides and let it cooled down. If you have excess of glue, apply some heat with the lighter and let it cooled down again. After that, your are ready to go fishing!
Javier Colón
회원 가입일: 03/18/22
145 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 18
30일 전: 70
전체 시간: 1,532
