주요 콘텐츠로 건너뛰기
How to Replace Asus Transformer Pad TF103C Headphone Jack
필요한 것
  1. How to Replace Asus Transformer Pad TF103C Headphone Jack, Headphone Jack: 1 단계, 이미지 1개 중 1개
    • Turn the power off.
    • Insert the plastic opening tool between the top and bottom covers of the laptop. The two covers are attached all along the outside of the laptop.
    • Use a thin screwdriver if you don't have an opening tool.
    • Gently pull upwards and carefully pry open the bottom and top covers.
  2. How to Replace Asus Transformer Pad TF103C Headphone Jack: 2 단계, 이미지 1개 중 1개
    • Slide the tool along all four edges of the laptop and continue to pull the tool upwards to fully remove the bottom case from the laptop.
  3. How to Replace Asus Transformer Pad TF103C Headphone Jack: 3 단계, 이미지 1개 중 1개
    • Remove the back cover once it is detached then set it aside.
    • Rotate your laptop to match the orientation shown in the picture to make the guide easier to follow.
  4. How to Replace Asus Transformer Pad TF103C Headphone Jack: 4 단계, 이미지 1개 중 1개
    • Remove the tape and unplug the wire that attaches to both speakers from the soundboard.
  5. How to Replace Asus Transformer Pad TF103C Headphone Jack: 5 단계, 이미지 1개 중 1개
    • Use the +J000 screwdriver to unscrew and remove the M2 screw and plastic bracket.
  6. How to Replace Asus Transformer Pad TF103C Headphone Jack: 6 단계, 이미지 1개 중 1개
    • Remove the black tape from the ribbon cable and separate the cable from the soundboard.
  7. How to Replace Asus Transformer Pad TF103C Headphone Jack: 7 단계, 이미지 1개 중 1개
    • Use the +J000 to remove the three mounting screws from the soundboard.
    • Keep the screws together and organized. (Label, if necessary).
  8. How to Replace Asus Transformer Pad TF103C Headphone Jack: 8 단계, 이미지 2개 중 1개 How to Replace Asus Transformer Pad TF103C Headphone Jack: 8 단계, 이미지 2개 중 2개
    • Remove the soundboard which has the headphone jack attached to it and replace with the new soundboard.
    • Once done reassemble your device, follow these instructions in reverse order.
결론
작성자
9다른 기여자 명과 함께
Tyler Ellis
회원 가입일: 10/28/15
668 평판
안내서 4개를 작성함
UMass Dartmouth, Team 3-6, Shastany Fall 2015 UMass Dartmouth, Team 3-6, Shastany Fall 2015 회원
UMASSD-SHASTANY-F15S3G6
4 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 11
전체 시간: 814
