주요 콘텐츠로 건너뛰기
How to Replace Basic Bag Lining
필요한 것
  1. How to Replace Basic Bag Lining, Bag Lining: 1 단계, 이미지 1개 중 1개
    • Assess the old bag lining you will be replacing.
    • Consider color, material, and amount of fabric needed for the new lining.
  2. How to Replace Basic Bag Lining: 2 단계, 이미지 3개 중 1개 How to Replace Basic Bag Lining: 2 단계, 이미지 3개 중 2개 How to Replace Basic Bag Lining: 2 단계, 이미지 3개 중 3개
    • At the seams, use your hands or sewing to carefully rip or cut out old bag lining.
  3. How to Replace Basic Bag Lining: 3 단계, 이미지 1개 중 1개
    • Lay out old bag lining on fabric and measure out the size of the new bag lining, adding an extra 2 cm on each side.
  4. How to Replace Basic Bag Lining: 4 단계, 이미지 2개 중 1개 How to Replace Basic Bag Lining: 4 단계, 이미지 2개 중 2개
    • Fold new fabric in half to create one closed end for the bag lining.
    • Cut out bag lining based on measurements from previous step.
  5. How to Replace Basic Bag Lining: 5 단계, 이미지 1개 중 1개
    • Stitch the two sides of fabric adjacent to the folded side to create a rectangle with one opening.
    • You can stitch by hand or use a sewing machine.
    • Use stitches small and tight enough to ensure new lining remains intact.
    • Finish stitching 2 cm from the end of the open side.
  6. How to Replace Basic Bag Lining: 6 단계, 이미지 1개 중 1개
    • Fold over extra 2 cm from the opening of the new bag lining outward to hide the raw edge of the fabric.
    • With a needle suitable for sewing through your bag material, attach the bag lining with a straight running stitch around the mouth of the bag.
    • See the article How to Work a Running Stitch from The Spruce Crafts to learn how to do a running stitch.
결승점
작성자
1다른 기여자 명과 함께
Ijada Nguyen
회원 가입일: 01/26/23
133 평판
안내서 1개를 작성함
UC Davis, Team 1-1, Morris Winter 2023 UC Davis, Team 1-1, Morris Winter 2023 회원
UCD-MORRIS-W23S1G1
2 회원들
안내서 1개 작성
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 11
지난 30일: 67
전체 시간: 2,191
