주요 콘텐츠로 건너뛰기
How to Replace Cabinet Door Bumpers
필요한 것
  1. How to Replace Cabinet Door Bumpers, Cabinet Door Bumpers: 1 단계, 이미지 3개 중 1개 How to Replace Cabinet Door Bumpers, Cabinet Door Bumpers: 1 단계, 이미지 3개 중 2개 How to Replace Cabinet Door Bumpers, Cabinet Door Bumpers: 1 단계, 이미지 3개 중 3개
    • Open the cabinet door to access the existing bumpers.
  2. How to Replace Cabinet Door Bumpers: 2 단계, 이미지 3개 중 1개 How to Replace Cabinet Door Bumpers: 2 단계, 이미지 3개 중 2개 How to Replace Cabinet Door Bumpers: 2 단계, 이미지 3개 중 3개
    • Use a plastic scraper to remove the existing bumpers.
    • Using a metal scraper or excessive force could scratch your cabinets.
  3. How to Replace Cabinet Door Bumpers: 3 단계, 이미지 3개 중 1개 How to Replace Cabinet Door Bumpers: 3 단계, 이미지 3개 중 2개 How to Replace Cabinet Door Bumpers: 3 단계, 이미지 3개 중 3개
    • Apply a small amount of adhesive remover to a paper towel.
    • Rub the area where the old bumpers were located to remove any sticky residue.
    • Use WD-40 or rubbing alcohol to remove sticky residue from stainless steel cabinets.
  4. How to Replace Cabinet Door Bumpers: 4 단계, 이미지 3개 중 1개 How to Replace Cabinet Door Bumpers: 4 단계, 이미지 3개 중 2개 How to Replace Cabinet Door Bumpers: 4 단계, 이미지 3개 중 3개
    • Clean the area with a damp cloth and mild soap to remove any remaining adhesive remover or residue.
  5. How to Replace Cabinet Door Bumpers: 5 단계, 이미지 1개 중 1개
    • Let the area dry completely.
  6. How to Replace Cabinet Door Bumpers: 6 단계, 이미지 3개 중 1개 How to Replace Cabinet Door Bumpers: 6 단계, 이미지 3개 중 2개 How to Replace Cabinet Door Bumpers: 6 단계, 이미지 3개 중 3개
    • Peel off the backing from the adhesive side of the new bumpers.
    • Place the new bumper onto the clean, dry surface where the old bumpers used to be.
    • Press the bumper onto the cabinet to secure the adhesive.
  7. How to Replace Cabinet Door Bumpers: 7 단계, 이미지 3개 중 1개 How to Replace Cabinet Door Bumpers: 7 단계, 이미지 3개 중 2개 How to Replace Cabinet Door Bumpers: 7 단계, 이미지 3개 중 3개
    • Open and close the cabinet doors a few times to ensure that the new bumpers are securely in place and effectively cushioning the doors.
결승점
작성자
3다른 기여자 명과 함께
Brenda M
회원 가입일: 06/23/24
145 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 53
전체 시간: 764
