주요 콘텐츠로 건너뛰기
How to Replace Concealed Cabinet Hinges
필요한 것
  1. How to Replace Concealed Cabinet Hinges, Hinge: 1 단계, 이미지 1/3 How to Replace Concealed Cabinet Hinges, Hinge: 1 단계, 이미지 2/3 How to Replace Concealed Cabinet Hinges, Hinge: 1 단계, 이미지 3/3
    • Remove the screws that are attached to the cabinet door.
    • Unscrew the top and bottom hinges even if you are only replacing one hinge.
    • Remove the cabinet door from the hinge.
    • You may need to wiggle or pry the door off.
  2. How to Replace Concealed Cabinet Hinges: 2 단계, 이미지 1/2 How to Replace Concealed Cabinet Hinges: 2 단계, 이미지 2/2
    • Remove the screws that go into the cabinet frame from the hinge, then remove the hinge.
    • Only the hinge being replaced needs to be removed.
  3. How to Replace Concealed Cabinet Hinges: 3 단계, 이미지 1/3 How to Replace Concealed Cabinet Hinges: 3 단계, 이미지 2/3 How to Replace Concealed Cabinet Hinges: 3 단계, 이미지 3/3
    • Insert the new hinge into the cabinet door's pre-cut hole.
    • Attach the hinge with the provided screws.
    • To avoid striping the screws, do not over tighten.
  4. How to Replace Concealed Cabinet Hinges: 4 단계, 이미지 1/1
    • Reattach the cabinet door to the cabinet frame.
    • Do not tighten the screws all the way. You will need to align the door later.
    • You may need a friend to hold the door while you screw it back into place.
  5. How to Replace Concealed Cabinet Hinges: 5 단계, 이미지 1/2 How to Replace Concealed Cabinet Hinges: 5 단계, 이미지 2/2
    • Lift or lower the cabinet door to align the hinges with its original location.
    • Changes in wood stain can serve as a useful alignment guide.
    • Tighten all the screws.
  6. How to Replace Concealed Cabinet Hinges: 6 단계, 이미지 1/3 How to Replace Concealed Cabinet Hinges: 6 단계, 이미지 2/3 How to Replace Concealed Cabinet Hinges: 6 단계, 이미지 3/3
    • Use this step to adjust the amount of space between the cabinet door and the cabinet frame.
    • Loosen the adjustment screws, but do not remove them.
    • Slide the cabinet door to your desired position.
    • Tighten the screws.
  7. How to Replace Concealed Cabinet Hinges: 7 단계, 이미지 1/1
    • Use this step if your cabinet door closes too hard or does not completely close.
    • Tighten this screw to keep the cabinet door from closing too hard. Loosen the screw to allow the cabinet door to close completely.
    • Do not completely remove this screw.
결승점
다른 4명이 해당 안내서를 완성하였습니다.
Naomi Frazier
회원 가입일: 04/28/17
171 평판
안내서 1개 작성함
UC Davis, Team S4-G4, Cole Spring 2017 UC Davis, Team S4-G4, Cole Spring 2017 회원
UCD-COLE-S17S4G4
3 회원들
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 35
30일 전: 94
전체 시간: 27,877
