주요 콘텐츠로 건너뛰기
How to Replace Concealed Cabinet Hinges
필요한 것
  1. How to Replace Concealed Cabinet Hinges, Hinge: 1 단계, 이미지 3개 중 1개 How to Replace Concealed Cabinet Hinges, Hinge: 1 단계, 이미지 3개 중 2개 How to Replace Concealed Cabinet Hinges, Hinge: 1 단계, 이미지 3개 중 3개
    • Remove the screws that are attached to the cabinet door.
    • Unscrew the top and bottom hinges even if you are only replacing one hinge.
    • Remove the cabinet door from the hinge.
    • You may need to wiggle or pry the door off.
  2. How to Replace Concealed Cabinet Hinges: 2 단계, 이미지 2개 중 1개 How to Replace Concealed Cabinet Hinges: 2 단계, 이미지 2개 중 2개
    • Remove the screws that go into the cabinet frame from the hinge, then remove the hinge.
    • Only the hinge being replaced needs to be removed.
  3. How to Replace Concealed Cabinet Hinges: 3 단계, 이미지 3개 중 1개 How to Replace Concealed Cabinet Hinges: 3 단계, 이미지 3개 중 2개 How to Replace Concealed Cabinet Hinges: 3 단계, 이미지 3개 중 3개
    • Insert the new hinge into the cabinet door's pre-cut hole.
    • Attach the hinge with the provided screws.
    • To avoid striping the screws, do not over tighten.
  4. How to Replace Concealed Cabinet Hinges: 4 단계, 이미지 1개 중 1개
    • Reattach the cabinet door to the cabinet frame.
    • Do not tighten the screws all the way. You will need to align the door later.
    • You may need a friend to hold the door while you screw it back into place.
  5. How to Replace Concealed Cabinet Hinges: 5 단계, 이미지 2개 중 1개 How to Replace Concealed Cabinet Hinges: 5 단계, 이미지 2개 중 2개
    • Lift or lower the cabinet door to align the hinges with its original location.
    • Changes in wood stain can serve as a useful alignment guide.
    • Tighten all the screws.
  6. How to Replace Concealed Cabinet Hinges: 6 단계, 이미지 3개 중 1개 How to Replace Concealed Cabinet Hinges: 6 단계, 이미지 3개 중 2개 How to Replace Concealed Cabinet Hinges: 6 단계, 이미지 3개 중 3개
    • Use this step to adjust the amount of space between the cabinet door and the cabinet frame.
    • Loosen the adjustment screws, but do not remove them.
    • Slide the cabinet door to your desired position.
    • Tighten the screws.
  7. How to Replace Concealed Cabinet Hinges: 7 단계, 이미지 1개 중 1개
    • Use this step if your cabinet door closes too hard or does not completely close.
    • Tighten this screw to keep the cabinet door from closing too hard. Loosen the screw to allow the cabinet door to close completely.
    • Do not completely remove this screw.
결승점
다른 4명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Naomi Frazier
회원 가입일: 04/28/17
171 평판
안내서 1개를 작성함
UC Davis, Team S4-G4, Cole Spring 2017 UC Davis, Team S4-G4, Cole Spring 2017 회원
UCD-COLE-S17S4G4
3 회원들
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 23
지난 30일: 141
전체 시간: 29,801
