주요 콘텐츠로 건너뛰기
How to Replace Damaged Clarinet Cork With Foam
필요한 것
  1. How to Replace Damaged Clarinet Cork With Foam, How to Replace Damaged Clarinet Cork With Foam: 1 단계, 이미지 1/1
    • Take your clarinet and identify where the cork is damaged and assess the extent of the damaged cork.
  2. How to Replace Damaged Clarinet Cork With Foam: 2 단계, 이미지 1/1
    • With a small razor, start cutting the cork by creating a line vertically and horizontally.
  3. How to Replace Damaged Clarinet Cork With Foam: 3 단계, 이미지 1/2 How to Replace Damaged Clarinet Cork With Foam: 3 단계, 이미지 2/2
    • After cutting the cork vertically and horizontally, try removing as much cork as possible.
  4. How to Replace Damaged Clarinet Cork With Foam: 4 단계, 이미지 1/2 How to Replace Damaged Clarinet Cork With Foam: 4 단계, 이미지 2/2
    • With the small razor used to cut the cork, cut a piece of foam.
    • The size will depend on what part of the clarinet you are fixing.
    • Use a glue gun to bond the foam to the clarinet tenon.
  5. How to Replace Damaged Clarinet Cork With Foam: 5 단계, 이미지 1/1
    • After gluing the piece of foam, let it dry.
    • Assemble the clarinet until it fits completely.
  6. How to Replace Damaged Clarinet Cork With Foam: 6 단계, 이미지 1/1
    • Finally, the clarinet is fixed, and it will function properly until you are able to replace the cork.
결론
After complete all the steps the clarinet is ready and the musician may continue performing with it. A simple repair like this allows the musician to order clarinet parts that’ll take awhile to arrive.
다른 한 분이 해당 안내서를 완성하였습니다.
Adrian
회원 가입일: 03/18/22
157 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 14
전체 시간: 335
