주요 콘텐츠로 건너뛰기
How to Replace Field Hockey Stick Grip Tape
필요한 것
  1. How to Replace Field Hockey Stick Grip Tape, Grip Tape: 1 단계, 이미지 3개 중 1개 How to Replace Field Hockey Stick Grip Tape, Grip Tape: 1 단계, 이미지 3개 중 2개 How to Replace Field Hockey Stick Grip Tape, Grip Tape: 1 단계, 이미지 3개 중 3개
    • Use a cloth and an anti-bacterial spray to clean the Field Hockey stick.
  2. How to Replace Field Hockey Stick Grip Tape: 2 단계, 이미지 3개 중 1개 How to Replace Field Hockey Stick Grip Tape: 2 단계, 이미지 3개 중 2개 How to Replace Field Hockey Stick Grip Tape: 2 단계, 이미지 3개 중 3개
    • Unravel the old sticky tape starting from the top of the stick.
  3. How to Replace Field Hockey Stick Grip Tape: 3 단계, 이미지 3개 중 1개 How to Replace Field Hockey Stick Grip Tape: 3 단계, 이미지 3개 중 2개 How to Replace Field Hockey Stick Grip Tape: 3 단계, 이미지 3개 중 3개
    • Unravel old tape until it meets the end of the handle.
  4. How to Replace Field Hockey Stick Grip Tape: 4 단계, 이미지 2개 중 1개 How to Replace Field Hockey Stick Grip Tape: 4 단계, 이미지 2개 중 2개
    • Carefully cut the tape so that end of grip tape below can be taken off.
    • Handle scissors with care never holding the open blade.
  5. How to Replace Field Hockey Stick Grip Tape: 5 단계, 이미지 3개 중 1개 How to Replace Field Hockey Stick Grip Tape: 5 단계, 이미지 3개 중 2개 How to Replace Field Hockey Stick Grip Tape: 5 단계, 이미지 3개 중 3개
    • Unravel the old grip tape from the top of the stick that spirals down.
    • Stop unravelling once loose-end cap is exposed fully.
  6. How to Replace Field Hockey Stick Grip Tape: 6 단계, 이미지 2개 중 1개 How to Replace Field Hockey Stick Grip Tape: 6 단계, 이미지 2개 중 2개
    • Put glue around the circumference of the base of the loose cap.
    • Line up and press the cap back onto the stick.
    • Handle glue with care so as not to spill.
  7. How to Replace Field Hockey Stick Grip Tape: 7 단계, 이미지 1개 중 1개
    • Let the glue dry for at least 10 minutes.
  8. How to Replace Field Hockey Stick Grip Tape: 8 단계, 이미지 3개 중 1개 How to Replace Field Hockey Stick Grip Tape: 8 단계, 이미지 3개 중 2개 How to Replace Field Hockey Stick Grip Tape: 8 단계, 이미지 3개 중 3개
    • Using new gauze tape, re-wrap the stick applying pressure in an upwards motion.
  9. How to Replace Field Hockey Stick Grip Tape: 9 단계, 이미지 2개 중 1개 How to Replace Field Hockey Stick Grip Tape: 9 단계, 이미지 2개 중 2개
    • Once new gauze covers the handle, cut the tape from its source.
  10. How to Replace Field Hockey Stick Grip Tape: 10 단계, 이미지 3개 중 1개 How to Replace Field Hockey Stick Grip Tape: 10 단계, 이미지 3개 중 2개 How to Replace Field Hockey Stick Grip Tape: 10 단계, 이미지 3개 중 3개
    • Secure the gauze with sticky tape at the top of the handle.
    • Cut the sticky tape from its source before wrapping around the top of the handle.
  11. How to Replace Field Hockey Stick Grip Tape: 11 단계, 이미지 3개 중 1개 How to Replace Field Hockey Stick Grip Tape: 11 단계, 이미지 3개 중 2개 How to Replace Field Hockey Stick Grip Tape: 11 단계, 이미지 3개 중 3개
    • Secure the gauze with sticky tape at the bottom of the handle.
    • Cut the sticky tape from its source before wrapping around the bottom of the handle.
  12. How to Replace Field Hockey Stick Grip Tape: 12 단계, 이미지 1개 중 1개
    • Enjoy your new grip tape!
결승점
작성자
3다른 기여자 명과 함께
Sophia Juan
회원 가입일: 02/01/24
205 평판
안내서 1개를 작성함
UC Davis, Team 1-5, Andersen Winter 2024 UC Davis, Team 1-5, Andersen Winter 2024 회원
UCD-ANDERSEN-W24S1G5
3 회원들
안내서 1개 작성
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 15
전체 시간: 432
