주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
How to Replace HID Headlight Bulbs
  1. How to Replace HID Headlight Bulbs, HID Headlight Bulb: 1 단계, 이미지 2개 중 1개 How to Replace HID Headlight Bulbs, HID Headlight Bulb: 1 단계, 이미지 2개 중 2개
    • Open the hood and then locate the back of the headlights.
    댓글 쓰기
  2. How to Replace HID Headlight Bulbs: 2 단계, 이미지 1개 중 1개
    • Remove the cap covers behind the headlights.
    댓글 쓰기
  3. How to Replace HID Headlight Bulbs: 3 단계, 이미지 2개 중 1개 How to Replace HID Headlight Bulbs: 3 단계, 이미지 2개 중 2개
    • Once you can see the OEM headlight bulb, twist and unlock to take it out.
    댓글 쓰기
  4. How to Replace HID Headlight Bulbs: 4 단계, 이미지 2개 중 1개 How to Replace HID Headlight Bulbs: 4 단계, 이미지 2개 중 2개
    • For a lot of D1S and D3S, there's a bulb retainer, which you will need to remove.
    댓글 쓰기
  5. How to Replace HID Headlight Bulbs: 5 단계, 이미지 1개 중 1개
    • Examine your stock bulb. Make sure that the labeling on the OEM bulb is the same as the new HID bulb.
    • For example, this particular vehicle uses D1S stock bulb. You'll need to make sure that the HID replacement bulb is also labeled as D1S.
    • D1S and D3S are not interchangeable, so if you find that the labeling does not match, you will need to exchange for the correct size.
    댓글 쓰기
  6. How to Replace HID Headlight Bulbs: 6 단계, 이미지 3개 중 1개 How to Replace HID Headlight Bulbs: 6 단계, 이미지 3개 중 2개 How to Replace HID Headlight Bulbs: 6 단계, 이미지 3개 중 3개
    • Take a look at the pins inside of the bulb. You can see that there is 1 pin by itself, a gap, and then 2 pins together. When you connect the new HID headlight bulb to the adapter, the pin direction needs to match! Look closely at the adapter and you will see numbers denoting slots 1,2, and 4.
    • Make sure that the pins on the HID headlight bulb and the pin slots on the adapter directly match prior to connection. If you connect the HID headlight bulb and the adapter the wrong way, the connection will still go in, but the incorrect insert WILL cause the bulb to have issues such as not lighting up, flickering, or damage to your vehicle.
    • So before connecting the HID headlight bulb to the adapter, make sure that the pins from the HID headlight bulb match the corresponding open slots on the adapter.
    댓글 쓰기
  7. How to Replace HID Headlight Bulbs: 7 단계, 이미지 2개 중 1개 How to Replace HID Headlight Bulbs: 7 단계, 이미지 2개 중 2개
    • Now you can install the HID headlight bulb back with the original retainer and then insert it back the same way you removed the OEM bulb.
    댓글 쓰기
  8. How to Replace HID Headlight Bulbs: 8 단계, 이미지 2개 중 1개 How to Replace HID Headlight Bulbs: 8 단계, 이미지 2개 중 2개
    • Put all the components back in place and enjoy your new HID headlights.
    댓글 쓰기
결론
As you can see, it's very straight forward to install. Installing this HID Replacement Bulb will give you light when yours burnt out.
취소: 해당 안내서를 완성하지 않았습니다.
다른 7명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Eric Wu
회원 가입일: 01/21/15
3,600 평판
안내서 23개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 13
지난 7일: 68
지난 30일: 374
전체 시간: 10,052
