주요 콘텐츠로 건너뛰기
How to Replace Hardwood Flooring
필요한 것
  1. How to Replace Hardwood Flooring, How to Replace Hardwood Flooring: 1 단계, 이미지 1/1
    • Remove the hardwood, tile, or carpet flooring you are trying to replace to expose the foundation or plywood underneath. The methods will vary depending on the type of flooring that is being removed.
    • Be sure to remove extra fragments of the original flooring and clean the area of any debris.
  2. How to Replace Hardwood Flooring: 2 단계, 이미지 1/2 How to Replace Hardwood Flooring: 2 단계, 이미지 2/2
    • With a notched trowel, spread the GreenGrip hardwood adhesive over the foundation where you would like to lay the new flooring.
  3. How to Replace Hardwood Flooring: 3 단계, 이미지 1/2 How to Replace Hardwood Flooring: 3 단계, 이미지 2/2
    • Measure the planks of wood to organize them into a desired pattern, then cut each plank accordingly.
  4. How to Replace Hardwood Flooring: 4 단계, 이미지 1/1
    • Carefully place the boards on top of the glue, making sure to push the seams of the planks together.
  5. How to Replace Hardwood Flooring: 5 단계, 이미지 1/1
    • Some of the adhesive may come through the seams, so wipe off any excess glue with a wet rag.
  6. How to Replace Hardwood Flooring: 6 단계, 이미지 1/1
    • Let the glue cure for 24 hours and enjoy your beautiful new floor!
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Rori Tyrrell
회원 가입일: 02/23/21
157 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 8
30일 전: 37
전체 시간: 829
