주요 콘텐츠로 건너뛰기
How to Replace KBD67 Lite R3 Keyboard Switch Spring
필요한 것
  1. How to Replace KBD67 Lite R3 Keyboard Switch Spring, Switch Spring: 1 단계, 이미지 2개 중 1개 How to Replace KBD67 Lite R3 Keyboard Switch Spring, Switch Spring: 1 단계, 이미지 2개 중 2개
    • Align the keycap puller to the keycap.
    • Gently pull vertically on the keycap to remove it, exposing the key switch.
  2. How to Replace KBD67 Lite R3 Keyboard Switch Spring: 2 단계, 이미지 3개 중 1개 How to Replace KBD67 Lite R3 Keyboard Switch Spring: 2 단계, 이미지 3개 중 2개 How to Replace KBD67 Lite R3 Keyboard Switch Spring: 2 단계, 이미지 3개 중 3개
    • Align the key switch puller with the key switch that you're removing.
    • Pull the key switch out of the keyboard.
  3. How to Replace KBD67 Lite R3 Keyboard Switch Spring: 3 단계, 이미지 3개 중 1개 How to Replace KBD67 Lite R3 Keyboard Switch Spring: 3 단계, 이미지 3개 중 2개 How to Replace KBD67 Lite R3 Keyboard Switch Spring: 3 단계, 이미지 3개 중 3개
    • Locate the side of the switch that has latches.
    • Place the side of the switch with latches on top of the key switch opener legs.
    • Apply gentle force pushing the switch down on the switch opener to open up the switch.
  4. How to Replace KBD67 Lite R3 Keyboard Switch Spring: 4 단계, 이미지 2개 중 1개 How to Replace KBD67 Lite R3 Keyboard Switch Spring: 4 단계, 이미지 2개 중 2개
    • Remove the top housing and stem to reveal the switch spring.
    • Remove the switch spring and proceed to replace it with another spring of your choice.
  5. How to Replace KBD67 Lite R3 Keyboard Switch Spring: 5 단계, 이미지 3개 중 1개 How to Replace KBD67 Lite R3 Keyboard Switch Spring: 5 단계, 이미지 3개 중 2개 How to Replace KBD67 Lite R3 Keyboard Switch Spring: 5 단계, 이미지 3개 중 3개
    • Locate the side of the switch that has legs, then place the switch on top of the spring. with the legs facing the metal plate.
    • Push the top and bottom housing together to assemble the switch.
    • Do not do this on the switch opener. The switch opener was used for photography purposes.
  6. How to Replace KBD67 Lite R3 Keyboard Switch Spring: 6 단계, 이미지 3개 중 1개 How to Replace KBD67 Lite R3 Keyboard Switch Spring: 6 단계, 이미지 3개 중 2개 How to Replace KBD67 Lite R3 Keyboard Switch Spring: 6 단계, 이미지 3개 중 3개
    • Locate the switch pin holes on your keyboard.
    • Locate the pins on your key switch and line it up with the keyboard pin holes.
    • Apply gentle force pushing down until it clicks onto place.
  7. How to Replace KBD67 Lite R3 Keyboard Switch Spring: 7 단계, 이미지 1개 중 1개
    • Put the key cap back onto the switch.
    • Test the keyboard input and ensure that everything is functioning correctly.
결론
작성자
1다른 기여자 명과 함께
Frank Loi
회원 가입일: 07/04/22
145 평판
안내서 1개를 작성함
York University, Team M-14, Allen Summer 2022 York University, Team M-14, Allen Summer 2022 회원
YORK-ALLEN-SU22SMG14
1 회원
안내서 2개를 작성함
1가이드 댓글
Frank you did an amazing job on this one. I always wondered how to replace a keyboard key and finally you provided a perfect guide. Your introduction covers everything one needs to know including the parts required - thank you for the where to buy links. Talking about the guide it's clear and precise - all steps are documented well with those amazing parts focused pictures. Language is easy to read and understand. After reading your guide I feel more confident now to replace the key or the spring within.
Krushi Patel - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 9
지난 30일: 50
전체 시간: 1,278
