주요 콘텐츠로 건너뛰기
How to Replace Keys on a Keyboard
필요한 것
  1. How to Replace Keys on a Keyboard, Individual Keys: 1 단계, 이미지 2개 중 1개 How to Replace Keys on a Keyboard, Individual Keys: 1 단계, 이미지 2개 중 2개
    • Loosen the key by prying all four corners gently with your spudger.
    • Make sure your keyboard is unplugged before performing any of these steps.
  2. How to Replace Keys on a Keyboard: 2 단계, 이미지 2개 중 1개 How to Replace Keys on a Keyboard: 2 단계, 이미지 2개 중 2개
    • Wedge the tip of the spudger under the bottom of the key and carefully lift up until the key pops loose.
    • If the key will not come out, or seems like too much force is needed, try step one again.
  3. How to Replace Keys on a Keyboard: 3 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Use tweezers to remove any contaminants that were preventing the key from being pressed down from the now open hole on your keyboard.
    • Do not to grab the actual button, as breaking that could damage your keyboard permanently.
  4. How to Replace Keys on a Keyboard: 4 단계, 이미지 1개 중 1개
    • Clean your keys with compressed air by blowing around the removed key.
  5. How to Replace Keys on a Keyboard: 5 단계, 이미지 2개 중 1개 How to Replace Keys on a Keyboard: 5 단계, 이미지 2개 중 2개
    • Push in the clean keys until you hear a popping sound.
    • The keys should click in easily, so if you are having trouble try realigning the key with its hole.
    • If you removed multiple keys, make sure they are in their proper spot and orientation.
결론
Congratulations! You now have a keyboard with fully functional keys!
다른 7명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Cooper
회원 가입일: 02/24/15
493 평판
안내서 2개를 작성함
Cal Poly, Team 24-6, Green Winter 2015 Cal Poly, Team 24-6, Green Winter 2015 회원
CPSU-GREEN-W15S24G6
4 회원들
안내서 16개를 작성함
2가이드 댓글
This is How to CLEAN keys, not replace them. Duh.
Mike Miller - 답글
I came looking for how to replace the problematic ones like + on numpad :<
Eskalina Cvrnkalikova - 답글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 40
지난 30일: 177
전체 시간: 20,031
