이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Wedge the tip of the spudger under the bottom of the key and carefully lift up until the key pops loose.
Use tweezers to remove any contaminants that were preventing the key from being pressed down from the now open hole on your keyboard.
Push in the clean keys until you hear a popping sound.
The keys should click in easily, so if you are having trouble try realigning the key with its hole.
다른 6명이 해당 안내서를 완성하였습니다.
댓글 2개
This is How to CLEAN keys, not replace them. Duh.
I came looking for how to replace the problematic ones like + on numpad :<
