주요 콘텐츠로 건너뛰기
Coffee Table Metal Drawer Slides Replacement
필요한 것
  1. Coffee Table Metal Drawer Slides Replacement, Metal Drawer Slides: 1 단계, 이미지 2개 중 1개 Coffee Table Metal Drawer Slides Replacement, Metal Drawer Slides: 1 단계, 이미지 2개 중 2개
    • Make sure to empty the drawer completely before starting the replacement process.
  2. Coffee Table Metal Drawer Slides Replacement: 2 단계, 이미지 3개 중 1개 Coffee Table Metal Drawer Slides Replacement: 2 단계, 이미지 3개 중 2개 Coffee Table Metal Drawer Slides Replacement: 2 단계, 이미지 3개 중 3개
    • Remove the drawer carefully by pulling it out and slowly lifting it upwards until it is out.
  3. Coffee Table Metal Drawer Slides Replacement: 3 단계, 이미지 2개 중 1개 Coffee Table Metal Drawer Slides Replacement: 3 단계, 이미지 2개 중 2개
    • The drawer and drawer insertion should now look like this when the drawer is out completely.
  4. Coffee Table Metal Drawer Slides Replacement: 4 단계, 이미지 2개 중 1개 Coffee Table Metal Drawer Slides Replacement: 4 단계, 이미지 2개 중 2개
    • Remove the old gliders by taking the screwdriver and turning it counterclockwise (to the left) until the screw is completely out.
    • Make sure to take out all of the screws on the old gliders before proceeding to the next step.
    • The drill can be used instead of the screwdriver if wanted.
  5. Coffee Table Metal Drawer Slides Replacement: 5 단계, 이미지 2개 중 1개 Coffee Table Metal Drawer Slides Replacement: 5 단계, 이미지 2개 중 2개
    • This is what the old drawer slides will look like when taken off completely.
  6. Coffee Table Metal Drawer Slides Replacement: 6 단계, 이미지 2개 중 1개 Coffee Table Metal Drawer Slides Replacement: 6 단계, 이미지 2개 중 2개
    • Measure the new drawer slides.
  7. Coffee Table Metal Drawer Slides Replacement: 7 단계, 이미지 2개 중 1개 Coffee Table Metal Drawer Slides Replacement: 7 단계, 이미지 2개 중 2개
    • Measure the drawer and the drawer insertion and make sure that the new drawer slides will fit before proceeding to the next step.
  8. Coffee Table Metal Drawer Slides Replacement: 8 단계, 이미지 2개 중 1개 Coffee Table Metal Drawer Slides Replacement: 8 단계, 이미지 2개 중 2개
    • If applicable, make new markings with the pencil if there needs to be new holes made for the new drawer slides.
    • The drill needs to be used if making new holes for the drawer slides.
  9. Coffee Table Metal Drawer Slides Replacement: 9 단계, 이미지 2개 중 1개 Coffee Table Metal Drawer Slides Replacement: 9 단계, 이미지 2개 중 2개
    • Make sure everything is lined up nice and neatly.
    • Proceed to screw on the new slides by turning clockwise (to the right) and make sure they are nice and screwed in completely.
  10. Coffee Table Metal Drawer Slides Replacement: 10 단계, 이미지 2개 중 1개 Coffee Table Metal Drawer Slides Replacement: 10 단계, 이미지 2개 중 2개
    • If applicable, take the pliers and use them to help place the screw in place for screwing.
    • This step is optional.
  11. Coffee Table Metal Drawer Slides Replacement: 11 단계, 이미지 2개 중 1개 Coffee Table Metal Drawer Slides Replacement: 11 단계, 이미지 2개 중 2개
    • Use the level and make sure the drawer slides are level before proceeding to the next step.
  12. Coffee Table Metal Drawer Slides Replacement: 12 단계, 이미지 3개 중 1개 Coffee Table Metal Drawer Slides Replacement: 12 단계, 이미지 3개 중 2개 Coffee Table Metal Drawer Slides Replacement: 12 단계, 이미지 3개 중 3개
    • The new drawer slides will look like this when put on completely.
    • The drawer slides on the drawer itself should have the wheels placed on the back.
    • The drawer slides in the drawer insertion should have the wheels placed in the front.
  13. Coffee Table Metal Drawer Slides Replacement: 13 단계, 이미지 3개 중 1개 Coffee Table Metal Drawer Slides Replacement: 13 단계, 이미지 3개 중 2개 Coffee Table Metal Drawer Slides Replacement: 13 단계, 이미지 3개 중 3개
    • Put the drawer back into the drawer insertion by aligning the wheels of each drawer slide.
    • Insert at an angle while slowly pushing the drawer downwards until it is completely in.
    • Make sure that the drawer is opening and closing smoothly.
결승점
작성자
1다른 기여자 명과 함께
Jaley F Scott
회원 가입일: 01/21/25
217 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 10
지난 30일: 22
전체 시간: 186
