주요 콘텐츠로 건너뛰기
How to Replace T-fal Avante T24-B Toaster Lever
필요한 것
  1. How to Replace T-fal Avante T24-B Toaster Lever, T-fal Avante T24-B Toaster Lever: 1 단계, 이미지 1개 중 1개
    • Make sure the toaster is unplugged before beginning.
  2. How to Replace T-fal Avante T24-B Toaster Lever: 2 단계, 이미지 3개 중 1개 How to Replace T-fal Avante T24-B Toaster Lever: 2 단계, 이미지 3개 중 2개 How to Replace T-fal Avante T24-B Toaster Lever: 2 단계, 이미지 3개 중 3개
    • Remove the snap-on buttons from the front of the toaster.
    • They can be removed by pulling with your hands or gently prying with a flat tool.
  3. How to Replace T-fal Avante T24-B Toaster Lever: 3 단계, 이미지 3개 중 1개 How to Replace T-fal Avante T24-B Toaster Lever: 3 단계, 이미지 3개 중 2개 How to Replace T-fal Avante T24-B Toaster Lever: 3 단계, 이미지 3개 중 3개
    • Flip the toaster so that you can see its underside.
    • Remove the seven 20 mm Torx T3 screws from the bottom of the toaster.
  4. How to Replace T-fal Avante T24-B Toaster Lever: 4 단계, 이미지 2개 중 1개 How to Replace T-fal Avante T24-B Toaster Lever: 4 단계, 이미지 2개 중 2개
    • Turn the toaster so that you can access the back of the toaster
    • Remove the 3 15 mm Torx T3 screws from the back of the toaster.
  5. How to Replace T-fal Avante T24-B Toaster Lever: 5 단계, 이미지 2개 중 1개 How to Replace T-fal Avante T24-B Toaster Lever: 5 단계, 이미지 2개 중 2개
    • Pull off the toaster casing.
  6. How to Replace T-fal Avante T24-B Toaster Lever: 6 단계, 이미지 2개 중 1개 How to Replace T-fal Avante T24-B Toaster Lever: 6 단계, 이미지 2개 중 2개
    • Unplug the casing so that it does not get in your way.
    • Unplug both wires connecting the casing to the internals of the toaster.
  7. How to Replace T-fal Avante T24-B Toaster Lever: 7 단계, 이미지 3개 중 1개 How to Replace T-fal Avante T24-B Toaster Lever: 7 단계, 이미지 3개 중 2개 How to Replace T-fal Avante T24-B Toaster Lever: 7 단계, 이미지 3개 중 3개
    • Pry both sides of the broken lever at the front of the toaster away and remove it.
  8. How to Replace T-fal Avante T24-B Toaster Lever: 8 단계, 이미지 3개 중 1개 How to Replace T-fal Avante T24-B Toaster Lever: 8 단계, 이미지 3개 중 2개 How to Replace T-fal Avante T24-B Toaster Lever: 8 단계, 이미지 3개 중 3개
    • Snap the replacement lever into place.
    • Attach one side first, then snap the other side on to fully attach the lever.
결론
작성자
1다른 기여자 명과 함께
Cameron Johnson
회원 가입일: 01/16/23
157 평판
안내서 1개를 작성함
2가이드 댓글
Thank you so much!
S J - 답글
where do you get the replacement lever ?
Francois Rehel - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 14
지난 30일: 39
전체 시간: 1,216
