주요 콘텐츠로 건너뛰기
How to Replace The Bulb In A Spice Lab Himalayan Crystal Salt Lamp
  1. How to Replace The Bulb In A Spice Lab Himalayan Crystal Salt Lamp, Spice Lab Himalayan Crystal Salt Lamp Bulb Replacement: 1 단계, 이미지 1/1
    • Rotate the power switch in the counterclockwise direction to halt electricity flow to the lamp.
    • Be sure to unplug the lamp to mitigate risk.
    • Wait 5-10 minutes to allow the bulb to cool before continuing.
    • Salt lamps, especially this model, are very dense and capable of causing damage to you or your environment if dropped.
    • Be sure to perform this fix on a sturdy and level surface.
  2. How to Replace The Bulb In A Spice Lab Himalayan Crystal Salt Lamp: 2 단계, 이미지 1/1
    • Flip the lamp so that the base is accessible.
  3. How to Replace The Bulb In A Spice Lab Himalayan Crystal Salt Lamp: 3 단계, 이미지 1/1
    • Using your hands, pull the black circular light fixture out of the salt lamp.
  4. How to Replace The Bulb In A Spice Lab Himalayan Crystal Salt Lamp: 4 단계, 이미지 1/1
    • Using your fingers, twist the light bulb in the counterclockwise direction to remove the bulb.
  5. How to Replace The Bulb In A Spice Lab Himalayan Crystal Salt Lamp: 5 단계, 이미지 1/1
    • Screw an E12 light bulb into the empty socket.
    • E12 light bulbs are 12 millimeters in diameter.
결론
Hopefully this fix has reinvigorated your salt lamp. Thank you for using our guide
다른 한 분이 해당 안내서를 완성하였습니다.
Matthew Atwill
회원 가입일: 02/20/19
145 평판
안내서 1개 작성함
University of Memphis, Team S2-G8, Baddour Spring 2019 University of Memphis, Team S2-G8, Baddour Spring 2019 회원
UM-BADDOUR-S19S2G8
2 회원들
안내서 1개 작성하였습니다
댓글 한 개
replacing salt lamp bulb is not a big deal , but finding a good salt lamp bulb which lasts long is hard
Jackie Sullivan - 답글
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 9
30일 전: 23
전체 시간: 5,576
