주요 콘텐츠로 건너뛰기
How to Replace Underside Fabric of a Chair
필요한 것
  1. How to Replace Underside Fabric of a Chair, Underside Fabric: 1 단계, 이미지 1/1
    • Turn the armchair on its back.
  2. How to Replace Underside Fabric of a Chair: 2 단계, 이미지 1/1
    • Use pliers to remove the staples from the chair frame.
    • If the staples are too difficult to remove, cut away the fabric with scissors.
  3. How to Replace Underside Fabric of a Chair: 3 단계, 이미지 1/1
    • Measure out the dimensions of the perimeter of the chair frame.
    • Add an extra inch to each side to allow for error.
  4. How to Replace Underside Fabric of a Chair: 4 단계, 이미지 1/2 How to Replace Underside Fabric of a Chair: 4 단계, 이미지 2/2
    • Trace the dimensions onto the new fabric.
    • Cut along the traced lines.
  5. How to Replace Underside Fabric of a Chair: 5 단계, 이미지 1/1
    • Fold under approximately a 1-inch allowance from the fabric’s edges.
    • Adjust the folded edges as needed to the correct size.
  6. How to Replace Underside Fabric of a Chair: 6 단계, 이미지 1/2 How to Replace Underside Fabric of a Chair: 6 단계, 이미지 2/2
    • Use a staple gun to staple the fabric to the chair frame starting at one corner.
    • If the staples do not go all the way into the chair frame, tap lightly with a hammer.
  7. How to Replace Underside Fabric of a Chair: 7 단계, 이미지 1/1
    • Sit the chair upright and make sure the fabric is not visible or sagging.
    • If the fabric is visible, remove the staples from the closest corner and pull taut.
결승점
다른 3명이 해당 안내서를 완성하였습니다.
Nicole Keller
회원 가입일: 06/09/16
294 평판
안내서 1개 작성함
Texas Tech, Team 3-3, Rauch SU 2016 Texas Tech, Team 3-3, Rauch SU 2016 회원
TTU-RAUCH-SU16S3G3
2 회원들
안내서 1개 작성하였습니다
댓글 2개
excellent ways to repair the home furniture. thanks for your ways of writing such a good article about furniture.
Nice post written by Nicole Keller.
http://www.birchi.in/kids-and-baby/kids-...
Birchi In - 답글
Thanks a lot! Wish I knew this a couple of weeks ago. Instead, I went and bought two all new 1 seater sofas in Sydney,
Lucas Bergman - 답글
댓글 쓰기
조회 통계:
24 시간 전: 9
7일 전: 48
30일 전: 251
전체 시간: 22,118
