주요 콘텐츠로 건너뛰기
How to Replace Velcro on a Baseball Cap
필요한 것
  1. How to Replace Velcro on a Baseball Cap, How to Replace Velcro on a Baseball Cap: 1 단계, 이미지 3개 중 1개 How to Replace Velcro on a Baseball Cap, How to Replace Velcro on a Baseball Cap: 1 단계, 이미지 3개 중 2개 How to Replace Velcro on a Baseball Cap, How to Replace Velcro on a Baseball Cap: 1 단계, 이미지 3개 중 3개
    • Use a seam ripper to remove the stitching between the velcro and the hat.
    • Make sure to fully remove the velcro by also seam ripping the fold inside the hat.
    • Repeat this step on the other strap.
  2. How to Replace Velcro on a Baseball Cap: 2 단계, 이미지 2개 중 1개 How to Replace Velcro on a Baseball Cap: 2 단계, 이미지 2개 중 2개
    • Use a measuring tape to measure how much velcro you will need.
  3. How to Replace Velcro on a Baseball Cap: 3 단계, 이미지 1개 중 1개
    • Cut the precise amount of velcro to be sewn onto the hat.
  4. How to Replace Velcro on a Baseball Cap: 4 단계, 이미지 1개 중 1개
    • Pin the new velcro onto the hat.
    • This will make sure both pieces stay in place when you start to sew the velcro in place.
  5. How to Replace Velcro on a Baseball Cap: 5 단계, 이미지 3개 중 1개 How to Replace Velcro on a Baseball Cap: 5 단계, 이미지 3개 중 2개 How to Replace Velcro on a Baseball Cap: 5 단계, 이미지 3개 중 3개
    • To prepare for sewing, thread the needle with a thread color of your choice.
    • Pull the thread through the loop.
    • Measure about 24 inches
    • Make sure to leave an even amount of thread on either side of the needle.
    • 12 inches on each side
    • Cut the thread.
    • Knot the ends of the thread together to secure.
  6. How to Replace Velcro on a Baseball Cap: 6 단계, 이미지 3개 중 1개 How to Replace Velcro on a Baseball Cap: 6 단계, 이미지 3개 중 2개 How to Replace Velcro on a Baseball Cap: 6 단계, 이미지 3개 중 3개
    • Use a running stitch to secure the velcro to the strap of the cap.
    • To do a running stitch: bring the needle up through the cap side of the strap and then the velcro until the knot at the end of the thread hits the fabric.
    • At this point, bring the needle back down through the velcro a few millimeters from where you started, following the direction you're trying to sew.
    • Keep bringing the needle up and down through the strap and velcro, moving the same distance each time. Repeat this until you have sewn around the entire piece of velcro to secure it.
  7. How to Replace Velcro on a Baseball Cap: 7 단계, 이미지 1개 중 1개
    • When you come to the end, knot the thread next to the last running stitch to finish it.
  8. How to Replace Velcro on a Baseball Cap: 8 단계, 이미지 1개 중 1개
    • Repeat steps 4 - 7 on the remaining strap using the other side of the velcro.
    • Once finished, the velcro should be securely sewn on the baseball cap and ready to use.
결승점
다른 2명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Vi Truong
회원 가입일: 10/26/18
221 평판
안내서 1개를 작성함
UC Davis, Team S1-G9, Bender Fall 2018 UC Davis, Team S1-G9, Bender Fall 2018 회원
UCD-BENDER-F18S1G9
3 회원들
안내서 3개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 42
지난 30일: 196
전체 시간: 22,027
