주요 콘텐츠로 건너뛰기
How to Replace Your Cabin Filter
  1. How to Replace Your Cabin Filter, How to Replace Your Cabin Filter: 1 단계, 이미지 2개 중 1개 How to Replace Your Cabin Filter, How to Replace Your Cabin Filter: 1 단계, 이미지 2개 중 2개
    • Open your glovebox, and look for the tamper. Put a little outward pressure on it; it should just pop off.
  2. How to Replace Your Cabin Filter: 2 단계, 이미지 2개 중 1개 How to Replace Your Cabin Filter: 2 단계, 이미지 2개 중 2개
    • Squeeze the sides of the glove box and lower.
  3. How to Replace Your Cabin Filter: 3 단계, 이미지 1개 중 1개
    • Remove the glove box from its hinges and set aside.
  4. How to Replace Your Cabin Filter: 4 단계, 이미지 2개 중 1개 How to Replace Your Cabin Filter: 4 단계, 이미지 2개 중 2개
    • Pull gently to remove the cabin filter. Some cars may have a cover that must be removed before the cabin filter can be accessed. Be sure to note how the cabin filter was installed so you can install the new one in the same manner.
    • Install your new cabin filter.
결론
To reassemble, carefully place the glove box back on its hinges, squeeze the sides, and reattach the damper. That's it. You've changed your cabin filter.
다른 6명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Chaya Milchtein
회원 가입일: 07/06/23
1,207 평판
안내서 5개를 작성함
2가이드 댓글
My non factory air filter makes a constant whistling sound when installed and the heater on. Toyota decided to “fix” it by just removing it. No more whistling but no more filter either. They said I could buy a new factory filter and they would install it but I don't have the $80 it costs. Any thoughts or suggestions? Also does your book have pics? I really liked the pics above for the air filter replacement info. Thanks.
meanqueen80 - 답글
我的车是尼桑祺达,我已经更换了车内空调滤网,但是我感觉总是有灰尘以出风口飞出,为什么❓
Kevin - 답글
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 29
지난 30일: 93
전체 시간: 1,485
