주요 콘텐츠로 건너뛰기
2016-2022 Honda HR-V Smart Key Battery Replacement
필요한 것
  1. 2016-2022 Honda HR-V Smart Key Battery Replacement, Opening key fob: 1 단계, 이미지 3개 중 1개 2016-2022 Honda HR-V Smart Key Battery Replacement, Opening key fob: 1 단계, 이미지 3개 중 2개 2016-2022 Honda HR-V Smart Key Battery Replacement, Opening key fob: 1 단계, 이미지 3개 중 3개
    • Turn key over so "H" is in your view.
    • Swipe the small switch below the "H" to the right while holding the key with both hands.
  2. 2016-2022 Honda HR-V Smart Key Battery Replacement, Taking key out of key fob: 2 단계, 이미지 3개 중 1개 2016-2022 Honda HR-V Smart Key Battery Replacement, Taking key out of key fob: 2 단계, 이미지 3개 중 2개 2016-2022 Honda HR-V Smart Key Battery Replacement, Taking key out of key fob: 2 단계, 이미지 3개 중 3개
    • Slide the valet key out from the remote.
    • Insert the valet key in between the two black rectangles on the edge of the remote.
    • Turn the key to the right to pry the two parts open.
  3. 2016-2022 Honda HR-V Smart Key Battery Replacement, Taking battery out: 3 단계, 이미지 3개 중 1개 2016-2022 Honda HR-V Smart Key Battery Replacement, Taking battery out: 3 단계, 이미지 3개 중 2개 2016-2022 Honda HR-V Smart Key Battery Replacement, Taking battery out: 3 단계, 이미지 3개 중 3개
    • The valet key shell will split into two parts.
    • Using minimal force take the battery out with your finger or a plastic prying tool.
    • Lift the battery out.
  4. 2016-2022 Honda HR-V Smart Key Battery Replacement, Replacing battery: 4 단계, 이미지 3개 중 1개 2016-2022 Honda HR-V Smart Key Battery Replacement, Replacing battery: 4 단계, 이미지 3개 중 2개 2016-2022 Honda HR-V Smart Key Battery Replacement, Replacing battery: 4 단계, 이미지 3개 중 3개
    • Insert the new battery by putting the bottom of battery in big teeth first.
    • Push the top of the battery into place.
  5. 2016-2022 Honda HR-V Smart Key Battery Replacement, Putting key fob back together: 5 단계, 이미지 2개 중 1개 2016-2022 Honda HR-V Smart Key Battery Replacement, Putting key fob back together: 5 단계, 이미지 2개 중 2개
    • Push the two halves of the key together.
    • Align the edges and seal it in place by pressing the sides of the shell together.
  6. 2016-2022 Honda HR-V Smart Key Battery Replacement, Inserting key back into key fob: 6 단계, 이미지 2개 중 1개 2016-2022 Honda HR-V Smart Key Battery Replacement, Inserting key back into key fob: 6 단계, 이미지 2개 중 2개
    • Insert the valet key back into the designated slot opposite of the silver loop.
    • Smart key battery is replaced and ready to use!
결론
다른 5명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Cindy Zarate
회원 가입일: 01/05/21
259 평판
안내서 1개를 작성함
2가이드 댓글
Easy-to-use guide, I didn't even know that there was a key inside of the fob...Great demo on a do it yourself and save yourself money that is needed else where...Thank you for sharing....
Jannette Needs - 답글
A volte la macchina non si avvia al primo colpo....è x colpa della batteria auto che si sta scaricando o della batteria del telecomando che si sta esaurendo?
francesco stano - 답글
댓글 쓰기
조회 통계:
지난 24시간: 64
지난 7일: 456
지난 30일: 2,311
전체 시간: 63,812
