주요 콘텐츠로 건너뛰기
How to Replace a Beaded Bracelet String
필요한 것
  1. How to Replace a Beaded Bracelet String, String: 1 단계, 이미지 1/2 How to Replace a Beaded Bracelet String, String: 1 단계, 이미지 2/2
    • Test your bracelet by wearing it on your wrist.
    • If it is loose, sagging (as pictured), or fully snapped, this is a sign that you may need to replace the string.
  2. How to Replace a Beaded Bracelet String: 2 단계, 이미지 1/1
    • Cut the old string using scissors.
  3. How to Replace a Beaded Bracelet String: 3 단계, 이미지 1/1
    • Separate the beads from the old string.
  4. How to Replace a Beaded Bracelet String: 4 단계, 이미지 1/1
    • Measure the new string by wrapping it 1.5 times around your wrist.
    • If you want a loose fit, add extra slack, otherwise pull it flush against skin.
    • Make sure to leave at least 2 in (5.1cm) of excess string for the knot.
  5. How to Replace a Beaded Bracelet String: 5 단계, 이미지 1/1
    • Cut the new string at the desired length using scissors.
  6. How to Replace a Beaded Bracelet String: 6 단계, 이미지 1/1
    • Thread the beads onto the new string one at a time.
    • You can use tweezers to hold the beads as you thread.
  7. How to Replace a Beaded Bracelet String: 7 단계, 이미지 1/2 How to Replace a Beaded Bracelet String: 7 단계, 이미지 2/2
    • Tie a square knot to secure the bracelet.
    • Cross both ends to form an "X" shape.
    • Loop one end of the string over the other to form a simple knot.
    • Tie another simple knot, but this time, loop in the opposite direction. If you initially looped the right side over the left, loop the left side over the right, and vice versa.
    • Pull tight to form a square knot.
  8. How to Replace a Beaded Bracelet String: 8 단계, 이미지 1/1
    • As an optional step, apply a dot of super glue to the knot.
    • Wait until the super glue fully dries before moving on, otherwise the knot may come undone.
  9. How to Replace a Beaded Bracelet String: 9 단계, 이미지 1/1
    • Trim the excess string.
    • Make sure to leave at least 1/2 in (1.3cm) of excess string for the knot.
  10. How to Replace a Beaded Bracelet String: 10 단계, 이미지 1/2 How to Replace a Beaded Bracelet String: 10 단계, 이미지 2/2
    • Test your bracelet by wearing it again. It should have a tighter fit.
결론
Lucas Wang
회원 가입일: 01/30/24
181 평판
안내서 1개 작성함
UC Davis, Team 2-5, Andersen Winter 2024 UC Davis, Team 2-5, Andersen Winter 2024 회원
UCD-ANDERSEN-W24S2G5
3 회원들
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 11
30일 전: 14
전체 시간: 134
