주요 콘텐츠로 건너뛰기
How to Replace a Bicycle Guide Pulley
필요한 것
  1. How to Replace a Bicycle Guide Pulley, Bicycle Guide Pulley: 1 단계, 이미지 1개 중 1개
    • Set your bike upside down by letting it stand on its handlebars and seat.
  2. How to Replace a Bicycle Guide Pulley: 2 단계, 이미지 3개 중 1개 How to Replace a Bicycle Guide Pulley: 2 단계, 이미지 3개 중 2개 How to Replace a Bicycle Guide Pulley: 2 단계, 이미지 3개 중 3개
    • If the pulley is still in place, unscrew it from the arm with the allen wrench.
    • Using the towel with the alcohol or degreaser, clean the pulley and check for cracks or broken teeth.
    • If any extensive damage is present, discard the pulley.
    • Be sure to clean and check the pulley's condition if it has fallen out of the arm.
  3. How to Replace a Bicycle Guide Pulley: 3 단계, 이미지 2개 중 1개 How to Replace a Bicycle Guide Pulley: 3 단계, 이미지 2개 중 2개
    • The replacement pulley should come with a bearing. Remove the bearing.
    • Grease the pulley and bearing thoroughly.
  4. How to Replace a Bicycle Guide Pulley: 4 단계, 이미지 2개 중 1개 How to Replace a Bicycle Guide Pulley: 4 단계, 이미지 2개 중 2개
    • Push the bearing back into the pulley.
  5. How to Replace a Bicycle Guide Pulley: 5 단계, 이미지 3개 중 1개 How to Replace a Bicycle Guide Pulley: 5 단계, 이미지 3개 중 2개 How to Replace a Bicycle Guide Pulley: 5 단계, 이미지 3개 중 3개
    • Place the teeth of the pulley against the chain, then push it with the chain into the derailleur arm.
  6. How to Replace a Bicycle Guide Pulley: 6 단계, 이미지 2개 중 1개 How to Replace a Bicycle Guide Pulley: 6 단계, 이미지 2개 중 2개
    • Grease the screw that holds the pulley in place.
    • Screw the pulley back into the derailleur with the allen wrench.
  7. How to Replace a Bicycle Guide Pulley: 7 단계, 이미지 1개 중 1개
    • While temporarily lifting the chain off the pulley, check to see if the pulley rotates freely.
  8. How to Replace a Bicycle Guide Pulley: 8 단계, 이미지 1개 중 1개
    • Push on the pedals to see if the derailleur is back in working order.
결론
To remove your pulley, see Step 2.
작성자
2다른 기여자 명과 함께
Kayla Bru
회원 가입일: 09/29/15
128 평판
안내서 1개를 작성함
Cal Poly, Team 10-6, Green Fall 2015 Cal Poly, Team 10-6, Green Fall 2015 회원
CPSU-GREEN-F15S10G6
3 회원들
안내서 3개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 9
전체 시간: 1,710
