주요 콘텐츠로 건너뛰기
How to Replace a Broken Blind Slat
필요한 것
  1. How to Replace a Broken Blind Slat, Horizontal Blind Slat: 1 단계, 이미지 1개 중 1개
    • Using the 7/32" flathead screwdriver, gently lift up the buttons located on the bottom rail of the blinds.
    • Make sure to be careful when lifting the bottom buttons to avoid injury and button damage.
  2. How to Replace a Broken Blind Slat: 2 단계, 이미지 2개 중 1개 How to Replace a Broken Blind Slat: 2 단계, 이미지 2개 중 2개
    • Remove the bottom rail buttons to expose knots at the end of the lifting cords.
    • Untie the knots.
  3. How to Replace a Broken Blind Slat: 3 단계, 이미지 1개 중 1개
    • Start at the highest damaged slat.
    • Begin pulling the lifting cords up through the route holes of all the following blind slats.
    • If you don't start from the highest slat, it will result in you doing way more work than you have to.
  4. How to Replace a Broken Blind Slat: 4 단계, 이미지 2개 중 1개 How to Replace a Broken Blind Slat: 4 단계, 이미지 2개 중 2개
    • Again, start with the highest slat.
    • Begin removing the broken slat(s) from in between the ladder strings.
  5. How to Replace a Broken Blind Slat: 5 단계, 이미지 1개 중 1개
    • Slide in the replacement slat(s).
    • Be sure the slat(s) sits in place upon the rungs of the ladder strings.
  6. How to Replace a Broken Blind Slat: 6 단계, 이미지 1개 중 1개
    • With the new replacement slats in place, begin at the highest slat.
    • Create a loop with the lifting cords.
    • Slide the loop through each routing hole on the same side of all the slats.
    • Repeat this step on the other side, and in the middle if your blinds have three routing holes.
  7. How to Replace a Broken Blind Slat: 7 단계, 이미지 3개 중 1개 How to Replace a Broken Blind Slat: 7 단계, 이미지 3개 중 2개 How to Replace a Broken Blind Slat: 7 단계, 이미지 3개 중 3개
    • Once you reach the bottom slat, thread the lifting cords back through the bottom rail.
    • Make sure the lifting cords are even in length and the bottom rail is aligned straight horizontally.
  8. How to Replace a Broken Blind Slat: 8 단계, 이미지 3개 중 1개 How to Replace a Broken Blind Slat: 8 단계, 이미지 3개 중 2개 How to Replace a Broken Blind Slat: 8 단계, 이미지 3개 중 3개
    • Use the 7/32" flathead screwdriver to push the excess lifting cords into the bottom rail holes.
    • Slide the buttons back over the ends of the cords.
    • At each bottom rail button, double knot the lifting cords.
  9. How to Replace a Broken Blind Slat: 9 단계, 이미지 1개 중 1개
    • Plug the buttons back into the bottom rail.
  10. How to Replace a Broken Blind Slat: 10 단계, 이미지 2개 중 1개 How to Replace a Broken Blind Slat: 10 단계, 이미지 2개 중 2개
    • Lastly, gently hammer the bottom rail buttons with the handle of the 7/32" flathead screwdriver to ensure the button is securely fastened.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Jazmine Atkins
회원 가입일: 01/25/20
274 평판
안내서 1개를 작성함
2가이드 댓글
Very good tutorial. Thank you.
LaReisa Cares - 답글
What happened when that string retracts and goes missing ?
Mary Nguyen - 답글
댓글 쓰기
조회 통계:
지난 24시간: 9
지난 7일: 47
지난 30일: 181
전체 시간: 20,028
