주요 콘텐츠로 건너뛰기
How to Replace a Broken Window Wand Tilt Mechanism
  1. How to Replace a Broken Window Wand Tilt Mechanism, Wand Tilt Mechanism: 1 단계, 이미지 3개 중 1개 How to Replace a Broken Window Wand Tilt Mechanism, Wand Tilt Mechanism: 1 단계, 이미지 3개 중 2개 How to Replace a Broken Window Wand Tilt Mechanism, Wand Tilt Mechanism: 1 단계, 이미지 3개 중 3개
    • Lift up the wand sleeve with your fingers to clear access for the wand to slide out.
    • Once the sleeve is pushed up, rotate the wand horizontally to unhook it from the tilt mechanism.
  2. How to Replace a Broken Window Wand Tilt Mechanism: 2 단계, 이미지 2개 중 1개 How to Replace a Broken Window Wand Tilt Mechanism: 2 단계, 이미지 2개 중 2개
    • Lift the header board off the window shade by gently prying up and away from the window blind.
  3. How to Replace a Broken Window Wand Tilt Mechanism: 3 단계, 이미지 3개 중 1개 How to Replace a Broken Window Wand Tilt Mechanism: 3 단계, 이미지 3개 중 2개 How to Replace a Broken Window Wand Tilt Mechanism: 3 단계, 이미지 3개 중 3개
    • Unhook the end clips on the window blind by pulling with your fingers toward yourself in an upward motion.
  4. How to Replace a Broken Window Wand Tilt Mechanism: 4 단계, 이미지 2개 중 1개 How to Replace a Broken Window Wand Tilt Mechanism: 4 단계, 이미지 2개 중 2개
    • Remove the window blind by pulling it away from the brackets.
  5. How to Replace a Broken Window Wand Tilt Mechanism: 5 단계, 이미지 3개 중 1개 How to Replace a Broken Window Wand Tilt Mechanism: 5 단계, 이미지 3개 중 2개 How to Replace a Broken Window Wand Tilt Mechanism: 5 단계, 이미지 3개 중 3개
    • Slide the end cap off the header to allow for more access.
    • Lift the center rod in an upward motion to unlock it from the header.
  6. How to Replace a Broken Window Wand Tilt Mechanism: 6 단계, 이미지 3개 중 1개 How to Replace a Broken Window Wand Tilt Mechanism: 6 단계, 이미지 3개 중 2개 How to Replace a Broken Window Wand Tilt Mechanism: 6 단계, 이미지 3개 중 3개
    • Remove the tilt wand mechanism by sliding it off the center rod.
  7. How to Replace a Broken Window Wand Tilt Mechanism: 7 단계, 이미지 3개 중 1개 How to Replace a Broken Window Wand Tilt Mechanism: 7 단계, 이미지 3개 중 2개 How to Replace a Broken Window Wand Tilt Mechanism: 7 단계, 이미지 3개 중 3개
    • Install the new tilt wand mechanism by sliding it on the center rod.
    • Once slid into position, reinsert the center rod by pushing down on the assembly.
  8. How to Replace a Broken Window Wand Tilt Mechanism: 8 단계, 이미지 1개 중 1개
    • Visually inspect alignment, fitment, and proper function of the newly installed tilt wand mechanism.
    • Insure the clip is securely held in place.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Daniel Resch
회원 가입일: 01/06/21
257 평판
안내서 1개를 작성함
1가이드 댓글
Thank you, my new apartment has a broken wind tilter mechanism. The plastic piece that hooks into the wand broke off the blind tilter. I have no idea what brand these vinyl two inch binds are. Can I glue the plastic piece back
Peggy G. Blass - 답글
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 43
지난 30일: 221
전체 시간: 23,126
