주요 콘텐츠로 건너뛰기
How to Replace a Button with a Sewing Machine
필요한 것
  1. How to Replace a Button with a Sewing Machine, Clothing Button: 1 단계, 이미지 1개 중 1개
    • Attach an open toed presser foot to your machine.
  2. How to Replace a Button with a Sewing Machine: 2 단계, 이미지 1개 중 1개
    • Thread your sewing machine with the proper colored thread.
  3. How to Replace a Button with a Sewing Machine: 3 단계, 이미지 1개 중 1개
    • Set your machine to a zig-zag stitch setting.
    • Adjust the stitch length to zero.
  4. How to Replace a Button with a Sewing Machine: 4 단계, 이미지 2개 중 1개 How to Replace a Button with a Sewing Machine: 4 단계, 이미지 2개 중 2개
    • Place the button under the presser foot and manually lower the needle to make sure that it is lined up with the first hole on the right.
    • Continue manually turning the needle to make sure that it clears the second hole on the left.
    • If the second hole is not lined up, adjust the stitch width accordingly.
  5. How to Replace a Button with a Sewing Machine: 5 단계, 이미지 1개 중 1개
    • Begin pushing on the foot pedal.
    • If the button has two holes, make about 10 stitches, or until the button is securely fastened.
    • If the button has four holes, sew diagonally about 5 stitches, pivot, and repeat on the opposite diagonal, forming an X.
  6. How to Replace a Button with a Sewing Machine: 6 단계, 이미지 1개 중 1개
    • Remove the finished garment from under the presser foot by clipping and leaving about 4 inches of excess thread.
  7. How to Replace a Button with a Sewing Machine: 7 단계, 이미지 1개 중 1개
    • Pull the top threads to the back of the garment.
    • Accomplish this by tugging on the bottom of the bobbin thread, forming a loop.
    • Using either your seam ripper or scissors, place the tip in the middle of the loop and pull it through. All four threads should be on the back of the garment.
  8. How to Replace a Button with a Sewing Machine: 8 단계, 이미지 1개 중 1개
    • Secure the button by tying the four threads together with a knot.
    • Clip the threads close to the knot.
  9. How to Replace a Button with a Sewing Machine: 9 단계, 이미지 1개 중 1개
    • The button is now finished and ready to be used.
결론
After following these steps, your garment will now be fixed.
작성자
2다른 기여자 명과 함께
Jackson Williams
회원 가입일: 09/19/22
169 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 26
지난 30일: 80
전체 시간: 1,563
