이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
Need to remove or replace an old cabinet door? Here's an easy step by step guide on removing and replacing a cabinet door using only a screwdriver.
필요한 것
Using a screwdriver, either a Flathead or a Phillips, remove the screws starting from the bottom of the door all the way to the top of the door to prevent the door from swinging.
To reassemble your cabinet, follow these instructions in reverse order.
다른 한 분이 해당 안내서를 완성하였습니다.
