주요 콘텐츠로 건너뛰기
How to Replace a Chain Link Fence Gate
필요한 것
  1. How to Replace a Chain Link Fence Gate, Chain link fence gate: 1 단계, 이미지 1개 중 1개
    • Spray WD-40 on each hinge bolt. This will make it easier to remove them.
  2. How to Replace a Chain Link Fence Gate: 2 단계, 이미지 3개 중 1개 How to Replace a Chain Link Fence Gate: 2 단계, 이미지 3개 중 2개 How to Replace a Chain Link Fence Gate: 2 단계, 이미지 3개 중 3개
    • Remove the bolt from the hinge strap on the fence post.
    • Wipe the excess lubricant from the bolt to avoid slipping.
    • Slide the loosened hinge strap up to remove the pin from the loop on the gate hinge.
    • Use a 9/16" socket wrench or a crescent wrench.
    • Repeat this process for the bottom hinge.
  3. How to Replace a Chain Link Fence Gate: 3 단계, 이미지 2개 중 1개 How to Replace a Chain Link Fence Gate: 3 단계, 이미지 2개 중 2개
    • Slide the gate away from the fence post set it aside.
  4. How to Replace a Chain Link Fence Gate: 4 단계, 이미지 1개 중 1개
    • Repeat the previous steps to remove the second gate pane.
  5. How to Replace a Chain Link Fence Gate: 5 단계, 이미지 1개 중 1개
    • Remove the unbolted post hinges from the fence posts.
  6. How to Replace a Chain Link Fence Gate: 6 단계, 이미지 3개 중 1개 How to Replace a Chain Link Fence Gate: 6 단계, 이미지 3개 중 2개 How to Replace a Chain Link Fence Gate: 6 단계, 이미지 3개 중 3개
    • Open the Galvanized Drive Gate Set and verify that you have four hinge pairs.
    • Separate one of the hinge pairs.
    • The Post Hinge has a pin. The Gate Hinge has a loop.
  7. How to Replace a Chain Link Fence Gate: 7 단계, 이미지 3개 중 1개 How to Replace a Chain Link Fence Gate: 7 단계, 이미지 3개 중 2개 How to Replace a Chain Link Fence Gate: 7 단계, 이미지 3개 중 3개
    • Slide the hinge strap onto the post so that the pin is facing down.
    • Slide a nut onto the end of the bolt.
    • Tighten the nut using the socket wrench.
  8. How to Replace a Chain Link Fence Gate: 8 단계, 이미지 3개 중 1개 How to Replace a Chain Link Fence Gate: 8 단계, 이미지 3개 중 2개 How to Replace a Chain Link Fence Gate: 8 단계, 이미지 3개 중 3개
    • Slide the hinge strap onto the post so that the pin is facing up.
    • Slide a bolt through the holes in the strap.
  9. How to Replace a Chain Link Fence Gate: 9 단계, 이미지 1개 중 1개
    • Attach the two gate hinges to the side of the gate frame with the loops facing out.
    • Keep the straps loose enough so that you can slide the hinges up and down on the gate frame, since you will need to adjust them once the gate is in position.
  10. How to Replace a Chain Link Fence Gate: 10 단계, 이미지 2개 중 1개 How to Replace a Chain Link Fence Gate: 10 단계, 이미지 2개 중 2개
    • Place blocks on the ground at the where you will install the gate. These will support the gate while you are connecting the hinges.
    • Lift the gate panel into position so that the gate lines up with the fence and at the desired height. Adjust the blocks as necessary to achieve the desired height.
  11. How to Replace a Chain Link Fence Gate: 11 단계, 이미지 2개 중 1개 How to Replace a Chain Link Fence Gate: 11 단계, 이미지 2개 중 2개
    • Slide the top gate hinge up as you slide the loop over the pin on the top post hinge.
    • Tighten the nut on the gate hinge straps.
    • Repeat for the bottom gate hinge.
  12. How to Replace a Chain Link Fence Gate: 12 단계, 이미지 2개 중 1개 How to Replace a Chain Link Fence Gate: 12 단계, 이미지 2개 중 2개
    • Adjust the hinges so that the gate can swing freely.
    • If the gate is too wide to close properly, adjust the angle of the hinges so that they are almost perpendicular, which brings the gate edge closer to the fence post.
  13. How to Replace a Chain Link Fence Gate: 13 단계, 이미지 3개 중 1개 How to Replace a Chain Link Fence Gate: 13 단계, 이미지 3개 중 2개 How to Replace a Chain Link Fence Gate: 13 단계, 이미지 3개 중 3개
    • Using a a 1/2" socket wrench or adjustable wrench, bolt the two latch plates on the inside of the gate frame together on one end.
    • Insert the latch between the two plates on the outside of the gate frame.
    • Insert a bolt and nut. Tighten to secure the latch.
    • Make sure the latch is loose enough to swing up and down.
  14. How to Replace a Chain Link Fence Gate: 14 단계, 이미지 3개 중 1개 How to Replace a Chain Link Fence Gate: 14 단계, 이미지 3개 중 2개 How to Replace a Chain Link Fence Gate: 14 단계, 이미지 3개 중 3개
    • Bolt the two post holders onto the gate frame.
    • Slide the post down through the post holders and secure in the ground.
결승점
다른 6명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Lucy Wiswall
회원 가입일: 01/18/17
272 평판
안내서 1개를 작성함
USF Sarasota-Manatee, Team 1-1, Stewart Spring 2017 USF Sarasota-Manatee, Team 1-1, Stewart Spring 2017 회원
USFSM-STEWART-S17S1G1
19 회원들
안내서 24개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 16
지난 30일: 52
전체 시간: 18,126
