주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
How to Replace a Corroded Car Battery Terminal
필요한 것
  1. How to Replace a Corroded Car Battery Terminal, Car Battery Terminal: 1 단계, 이미지 2개 중 1개 How to Replace a Corroded Car Battery Terminal, Car Battery Terminal: 1 단계, 이미지 2개 중 2개
    • Remember to remove your car key from the ignition and shut off the car before performing this guide.
    • Locate the terminals on the top of the car battery. Next to each terminal is a positive(+) or negative(-) sign, indicating the charge.
    • The positive terminal looks to be in working order, but the negative end has a lot of corrosion buildup. This terminal needs to be replaced.
    댓글 쓰기
  2. How to Replace a Corroded Car Battery Terminal: 2 단계, 이미지 2개 중 1개 How to Replace a Corroded Car Battery Terminal: 2 단계, 이미지 2개 중 2개
    • Find the nut located on the side of the terminal.
    • Using an adjustable wrench, rotate the nut counterclockwise to loosen it.
    • Use an appropriately-sized wrench or socket, not channel locks as shown in the photo.
    • You do not need to loosen the nut all the way off the bolt, but just enough to loosen the terminal's grip on the node.
    댓글 쓰기
  3. How to Replace a Corroded Car Battery Terminal: 3 단계, 이미지 2개 중 1개 How to Replace a Corroded Car Battery Terminal: 3 단계, 이미지 2개 중 2개
    • Always remember to remove the negative terminal first before the positive terminal. This will prevent shorting to the ground and possibly causing shock or a fire.
    • Carefully use a rag to lift up the terminal off of the battery node.
    • Be cautious when handling battery corrosion, as it can irritate the skin and is harmful if it comes in contact with your eyes.
    • Place the terminal on a rag or towel and make sure it doesn't come in contact with the battery node.
    댓글 쓰기
  4. How to Replace a Corroded Car Battery Terminal: 4 단계, 이미지 2개 중 1개 How to Replace a Corroded Car Battery Terminal: 4 단계, 이미지 2개 중 2개
    • On the positive terminal, locate the nut along the side.
    • Using the wrench, rotate the nut counterclockwise.
    • You do not need to fully loosen the nut off the bolt, but just enough for the terminal to be easily removed from the node.
    댓글 쓰기
  5. How to Replace a Corroded Car Battery Terminal: 5 단계, 이미지 2개 중 1개 How to Replace a Corroded Car Battery Terminal: 5 단계, 이미지 2개 중 2개
    • Using a rag, carefully remove the positive terminal from the battery node.
    • Place the terminal on a rag or towel, and make sure it does not come into contact with the battery node.
    댓글 쓰기
  6. How to Replace a Corroded Car Battery Terminal: 6 단계, 이미지 3개 중 1개 How to Replace a Corroded Car Battery Terminal: 6 단계, 이미지 3개 중 2개 How to Replace a Corroded Car Battery Terminal: 6 단계, 이미지 3개 중 3개
    • On the negative terminal, locate the nut on the side facing upwards.
    • Using the wrench, rotate the nut counterclockwise and remove it from the bolt.
    댓글 쓰기
  7. How to Replace a Corroded Car Battery Terminal: 7 단계, 이미지 3개 중 1개 How to Replace a Corroded Car Battery Terminal: 7 단계, 이미지 3개 중 2개 How to Replace a Corroded Car Battery Terminal: 7 단계, 이미지 3개 중 3개
    • Take the wire plate on top and remove it carefully from the bolt.
    • At this point, it is fine to handle the metal plate with your hands since the terminals are disconnected from the battery and there is nothing completing the circuit.
    • Remove the bottom wire plate from the bolt, placing it carefully to the side.
    댓글 쓰기
  8. How to Replace a Corroded Car Battery Terminal: 8 단계, 이미지 2개 중 1개 How to Replace a Corroded Car Battery Terminal: 8 단계, 이미지 2개 중 2개
    • Set aside the old battery terminal, and replace it with the new one.
    • Replace the wire plates in the order they were taken off.
    • Although it is not necessary that the plates be placed in the same order again, it is generally a good idea to go with the order that it came in.
    댓글 쓰기
  9. How to Replace a Corroded Car Battery Terminal: 9 단계, 이미지 2개 중 1개 How to Replace a Corroded Car Battery Terminal: 9 단계, 이미지 2개 중 2개
    • Place the flat washer and the screw-on head that came with the battery terminal onto the vertical bolt.
    • Tighten the head clockwise and make sure the wire plates are secured.
    • Not all battery terminal packs come with a washer and screw-on head. If your pack comes with a nut, use the wrench and tighten the bolt clockwise.
    댓글 쓰기
  10. How to Replace a Corroded Car Battery Terminal: 10 단계, 이미지 1개 중 1개
    • Using a rag, place the positive terminal back onto the positive node.
    댓글 쓰기
  11. How to Replace a Corroded Car Battery Terminal: 11 단계, 이미지 1개 중 1개
    • Place the negative terminal back onto the negative node.
    댓글 쓰기
  12. How to Replace a Corroded Car Battery Terminal: 12 단계, 이미지 3개 중 1개 How to Replace a Corroded Car Battery Terminal: 12 단계, 이미지 3개 중 2개 How to Replace a Corroded Car Battery Terminal: 12 단계, 이미지 3개 중 3개
    • On the negative terminal, use the wrench to rotate the side nut clockwise to tighten it.
    • Next, perform the same action on the side nut of the positive terminal.
    • To ensure a secure connection, be sure the nut is snug and that the terminal can't come off easily.
    댓글 쓰기
결승점
취소: 해당 안내서를 완성하지 않았습니다.
다른 22명이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
David Wright
회원 가입일: 02/23/15
775 평판
안내서 1개를 작성함
Cal Poly, Team 12-4, Green Winter 2015 Cal Poly, Team 12-4, Green Winter 2015 회원
CPSU-GREEN-W15S12G4
5 회원들
안내서 10개를 작성함
8가이드 댓글
Nice post. Shop car battery at batterybhai and their expert technical team come to install the battery with all battery replacement tools kit.
mayank tanwar - 답글 공유
very interesting post. Thanks for sharing it.
https://www.sarexports.com/product-categ...
Raman Malik - 답글 공유
I change negative terminal to new one still have corrosion why?
אנדריי מזילו - 답글 공유
They are corrotion after doinging this within a4 to 5 month time the red cable is worst
Carol - 답글 공유
Use Petroleum-Jelly (preferably) OR if not there then
use Vaseline onto both the Terminals( +, -ive) to prevent rusting of your both terminals of Battery PLEASE .
SANJAY KHANDELWAL - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 19
지난 7일: 135
지난 30일: 701
전체 시간: 149,406
