주요 콘텐츠로 건너뛰기
How to Replace a Curtain Rod
필요한 것
  1. How to Replace a Curtain Rod, Curtain Rod: 1 단계, 이미지 1/2 How to Replace a Curtain Rod, Curtain Rod: 1 단계, 이미지 2/2
    • Remove the rod off the hook from the wall carefully with your hands.
  2. How to Replace a Curtain Rod: 2 단계, 이미지 1/3 How to Replace a Curtain Rod: 2 단계, 이미지 2/3 How to Replace a Curtain Rod: 2 단계, 이미지 3/3
    • Remove the screws from the hooks using a Phillips screwdriver or power drill with a Phillips head.
  3. How to Replace a Curtain Rod: 3 단계, 이미지 1/2 How to Replace a Curtain Rod: 3 단계, 이미지 2/2
    • Use the tape measure to determine screw placement on the wall for the new curtain rod.
  4. How to Replace a Curtain Rod: 4 단계, 이미지 1/2 How to Replace a Curtain Rod: 4 단계, 이미지 2/2
    • Replace the Phillips head in the power drill with a drill bit.
    • Drill the holes into the wall for the screws to secure firmly.
  5. How to Replace a Curtain Rod: 5 단계, 이미지 1/1
    • Place the screw into the hole on the hook and drill it into the holes on the wall.
  6. How to Replace a Curtain Rod: 6 단계, 이미지 1/2 How to Replace a Curtain Rod: 6 단계, 이미지 2/2
    • Measure an equal distance between each hook. Repeat Step 5 for drilling in each hook on the wall.
  7. How to Replace a Curtain Rod: 7 단계, 이미지 1/2 How to Replace a Curtain Rod: 7 단계, 이미지 2/2
    • Insert the rod into the curtain hole, leaving at least two inches of the rod on each side uncovered for hook placement.
  8. How to Replace a Curtain Rod: 8 단계, 이미지 1/2 How to Replace a Curtain Rod: 8 단계, 이미지 2/2
    • Place the rod onto the curve of the hook for attachment. Then straighten out the curtain across the window.
결승점
Andrew Pfeiffer
회원 가입일: 02/22/21
157 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 35
전체 시간: 1,142
