주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
How to Replace a Damaged Gutter Segment
필요한 것
    1. How to Replace a Damaged Gutter Segment, Eavestrough Gutter Segment: 1 단계, 이미지 1개 중 1개
      • Identify the section of the gutter system that needs to be replaced, specifically the middle gutter.
      댓글 쓰기
    2. How to Replace a Damaged Gutter Segment: 2 단계, 이미지 2개 중 1개 How to Replace a Damaged Gutter Segment: 2 단계, 이미지 2개 중 2개
      • Using a screwdriver, remove the screws from the strip that holds the gutter to the wall.
      • Repeat this process for each strip along the length of the gutter.
      • Spread apart the strips to release the gutter.
      • When spreading apart the strips, they may have sharp edges. To ensure your safety, please use caution and wear protective gloves.
      댓글 쓰기
    3. How to Replace a Damaged Gutter Segment: 3 단계, 이미지 3개 중 1개 How to Replace a Damaged Gutter Segment: 3 단계, 이미지 3개 중 2개 How to Replace a Damaged Gutter Segment: 3 단계, 이미지 3개 중 3개
      • Locate the connecting points between the bottom gutter and the middle gutter.
      • Using a screwdriver, remove the screws.
      • Separate the bottom gutter from the middle gutter by sliding them apart.
      댓글 쓰기
    4. How to Replace a Damaged Gutter Segment: 4 단계, 이미지 3개 중 1개 How to Replace a Damaged Gutter Segment: 4 단계, 이미지 3개 중 2개 How to Replace a Damaged Gutter Segment: 4 단계, 이미지 3개 중 3개
      • Detach the top gutter from the connected fittings.
      • Position yourself securely on a ladder or elevated platform at the appropriate height to access the top gutter.
      • Place the removed top gutter and the middle gutter on the ground.
      • Inspect both the top gutter and the middle gutter for any damage. Assess whether they need to be entirely replaced or if repairs can be made.
      • If the damaged area is serious, you can only replace with a new segment (looking for environmentally friendly materials to protect the earth).
      댓글 쓰기
    5. How to Replace a Damaged Gutter Segment: 5 단계, 이미지 3개 중 1개 How to Replace a Damaged Gutter Segment: 5 단계, 이미지 3개 중 2개 How to Replace a Damaged Gutter Segment: 5 단계, 이미지 3개 중 3개
      • Slide the new middle gutter into the top gutter, inserting it gently until they are firmly connected.
      • Double-check that the alignment is correct and there are no gaps between the sections to avoid any drainage.
      • With the middle and top gutters connected, reattach the assembled gutters to the connected fittings.
      댓글 쓰기
    6. How to Replace a Damaged Gutter Segment: 6 단계, 이미지 3개 중 1개 How to Replace a Damaged Gutter Segment: 6 단계, 이미지 3개 중 2개 How to Replace a Damaged Gutter Segment: 6 단계, 이미지 3개 중 3개
      • Load a screw into the strip, positioning it so that it can be screwed into the holes of both the strip and the gutter.
      • Fold the strip around the gutter, aligning the holes of the strip with the corresponding holes on the gutter.
      • Screw the screws into the holes of the strip and the gutter, using a screwdriver.
      • Repeat this process for each strip along the length of the new middle gutter.
      • Take care not to overtighten the screw, as it may damage the gutter or strip the threads.
      댓글 쓰기
    7. How to Replace a Damaged Gutter Segment: 7 단계, 이미지 3개 중 1개 How to Replace a Damaged Gutter Segment: 7 단계, 이미지 3개 중 2개 How to Replace a Damaged Gutter Segment: 7 단계, 이미지 3개 중 3개
      • Position the bottom gutter in its intended location, ensuring that the holes on both pieces line up properly.
      • Using a screwdriver, tighten the screws to fasten the middle and bottom gutters together.
      • Replacement Complete!
      댓글 쓰기
결승점
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Gavin Luc
회원 가입일: 10/19/22
163 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 6
지난 7일: 30
지난 30일: 179
전체 시간: 3,426
