주요 콘텐츠로 건너뛰기
How to Replace a Dial-Lace System in a Hiking Boot
필요한 것
  1. How to Replace a Dial-Lace System in a Hiking Boot, Identify the repair area: 1 단계, 이미지 2개 중 1개 How to Replace a Dial-Lace System in a Hiking Boot, Identify the repair area: 1 단계, 이미지 2개 중 2개
    • Prepare all the tools needed for the repair and locate the part of the dial-lace system that needs repairing.
    • Note: in this guide we are replacing the whole dial and lace.
  2. How to Replace a Dial-Lace System in a Hiking Boot, Cut the old lace: 2 단계, 이미지 3개 중 1개 How to Replace a Dial-Lace System in a Hiking Boot, Cut the old lace: 2 단계, 이미지 3개 중 2개 How to Replace a Dial-Lace System in a Hiking Boot, Cut the old lace: 2 단계, 이미지 3개 중 3개
    • Cut the lace at starting at the bottom part of the shoe.
    • Use your hands to pull the lace upwards, following the direction of the red arrows.
  3. How to Replace a Dial-Lace System in a Hiking Boot, Remove the old dial: 3 단계, 이미지 3개 중 1개 How to Replace a Dial-Lace System in a Hiking Boot, Remove the old dial: 3 단계, 이미지 3개 중 2개 How to Replace a Dial-Lace System in a Hiking Boot, Remove the old dial: 3 단계, 이미지 3개 중 3개
    • Use a screwdriver with a flat and thin edge to remove the dial
    • Insert the screwdriver between the dial and the base and use a lever-like motion to push the dial up and out of the base.
  4. How to Replace a Dial-Lace System in a Hiking Boot, Prepare for lacing: 4 단계, 이미지 3개 중 1개 How to Replace a Dial-Lace System in a Hiking Boot, Prepare for lacing: 4 단계, 이미지 3개 중 2개 How to Replace a Dial-Lace System in a Hiking Boot, Prepare for lacing: 4 단계, 이미지 3개 중 3개
    • Insert the new lace inside the metal loop and prepare for the next step.
  5. How to Replace a Dial-Lace System in a Hiking Boot, Insert the lace: 5 단계, 이미지 3개 중 1개 How to Replace a Dial-Lace System in a Hiking Boot, Insert the lace: 5 단계, 이미지 3개 중 2개 How to Replace a Dial-Lace System in a Hiking Boot, Insert the lace: 5 단계, 이미지 3개 중 3개
    • Insert the lace through the first hole on the left side, then follow through the second hole of the opposite side.
  6. How to Replace a Dial-Lace System in a Hiking Boot, Continue lacing: 6 단계, 이미지 2개 중 1개 How to Replace a Dial-Lace System in a Hiking Boot, Continue lacing: 6 단계, 이미지 2개 중 2개
    • Insert the lace through the big loop that is located at the middle of the boot, then continue through the final loop on the left side.
  7. How to Replace a Dial-Lace System in a Hiking Boot, Secure the lace: 7 단계, 이미지 3개 중 1개 How to Replace a Dial-Lace System in a Hiking Boot, Secure the lace: 7 단계, 이미지 3개 중 2개 How to Replace a Dial-Lace System in a Hiking Boot, Secure the lace: 7 단계, 이미지 3개 중 3개
    • Following the direction of the red arrows, secure the lace by inserting it in the safety loop on the side, and pulling it upwards.
  8. How to Replace a Dial-Lace System in a Hiking Boot, Remove the lace from the metal loop: 8 단계, 이미지 3개 중 1개 How to Replace a Dial-Lace System in a Hiking Boot, Remove the lace from the metal loop: 8 단계, 이미지 3개 중 2개 How to Replace a Dial-Lace System in a Hiking Boot, Remove the lace from the metal loop: 8 단계, 이미지 3개 중 3개
    • Pull the metal loop outwards until it is completely separated from the lace.
    • Set the metal loop aside and prepare for the next step.
  9. How to Replace a Dial-Lace System in a Hiking Boot, Repeat the lacing: 9 단계, 이미지 3개 중 1개 How to Replace a Dial-Lace System in a Hiking Boot, Repeat the lacing: 9 단계, 이미지 3개 중 2개 How to Replace a Dial-Lace System in a Hiking Boot, Repeat the lacing: 9 단계, 이미지 3개 중 3개
    • Repeat the process on the other side of the shoe, this time starting from the right side.
  10. How to Replace a Dial-Lace System in a Hiking Boot, Measure the lace: 10 단계, 이미지 2개 중 1개 How to Replace a Dial-Lace System in a Hiking Boot, Measure the lace: 10 단계, 이미지 2개 중 2개
    • Use a measuring tape to measure the length of the lace
    • Note: the total length should be between 14 - 21 cm. In this example we measured 17cm
    • Cut the measured length and prepare for the next steps.
  11. How to Replace a Dial-Lace System in a Hiking Boot, Prepare the replacement dial: 11 단계, 이미지 3개 중 1개 How to Replace a Dial-Lace System in a Hiking Boot, Prepare the replacement dial: 11 단계, 이미지 3개 중 2개 How to Replace a Dial-Lace System in a Hiking Boot, Prepare the replacement dial: 11 단계, 이미지 3개 중 3개
    • Set the dial to the "unlocked" position.
    • Locate the two arrows shown in the shown in the green circles.
    • Rotate the dial until both arrows are aligned (yellow circle).
  12. How to Replace a Dial-Lace System in a Hiking Boot, Insert the metal loop: 12 단계, 이미지 3개 중 1개 How to Replace a Dial-Lace System in a Hiking Boot, Insert the metal loop: 12 단계, 이미지 3개 중 2개 How to Replace a Dial-Lace System in a Hiking Boot, Insert the metal loop: 12 단계, 이미지 3개 중 3개
    • Locate the hole in the dial. (red arrow)
    • Insert the metal loop inside the dial.
  13. How to Replace a Dial-Lace System in a Hiking Boot, Insert the lace into the dial: 13 단계, 이미지 3개 중 1개 How to Replace a Dial-Lace System in a Hiking Boot, Insert the lace into the dial: 13 단계, 이미지 3개 중 2개 How to Replace a Dial-Lace System in a Hiking Boot, Insert the lace into the dial: 13 단계, 이미지 3개 중 3개
    • Insert the lace inside the metal loop.
    • Once it the lace is inside, pull the metal loop upwards.
  14. How to Replace a Dial-Lace System in a Hiking Boot, Adjust the lace: 14 단계, 이미지 3개 중 1개 How to Replace a Dial-Lace System in a Hiking Boot, Adjust the lace: 14 단계, 이미지 3개 중 2개 How to Replace a Dial-Lace System in a Hiking Boot, Adjust the lace: 14 단계, 이미지 3개 중 3개
    • Push the dial to the end of the lace and repeat the previous steps of inserting the metal loop with lace on the other hole of the dial (green circle).
  15. How to Replace a Dial-Lace System in a Hiking Boot, Keep pulling the lace: 15 단계, 이미지 3개 중 1개 How to Replace a Dial-Lace System in a Hiking Boot, Keep pulling the lace: 15 단계, 이미지 3개 중 2개 How to Replace a Dial-Lace System in a Hiking Boot, Keep pulling the lace: 15 단계, 이미지 3개 중 3개
    • Once the metal loop has been inserted in the other hole, keep pulling it until the lace has passed through.
  16. How to Replace a Dial-Lace System in a Hiking Boot, Tighten the lace: 16 단계, 이미지 3개 중 1개 How to Replace a Dial-Lace System in a Hiking Boot, Tighten the lace: 16 단계, 이미지 3개 중 2개 How to Replace a Dial-Lace System in a Hiking Boot, Tighten the lace: 16 단계, 이미지 3개 중 3개
    • Use your hands to hold the dial and pull both ends of the lace upwards.
  17. How to Replace a Dial-Lace System in a Hiking Boot, Make a knot: 17 단계, 이미지 3개 중 1개 How to Replace a Dial-Lace System in a Hiking Boot, Make a knot: 17 단계, 이미지 3개 중 2개 How to Replace a Dial-Lace System in a Hiking Boot, Make a knot: 17 단계, 이미지 3개 중 3개
    • To secure the end of the lace, you need to make a "figure-eight" knot.
    • Start by twisting the lace twice and continue on the next step.
  18. How to Replace a Dial-Lace System in a Hiking Boot, Continue knotting: 18 단계, 이미지 3개 중 1개 How to Replace a Dial-Lace System in a Hiking Boot, Continue knotting: 18 단계, 이미지 3개 중 2개 How to Replace a Dial-Lace System in a Hiking Boot, Continue knotting: 18 단계, 이미지 3개 중 3개
    • Pick the end of the lace and gently introduce it in the little loop that is formed.
    • Once the end of the lace has passed through the loop, pull the knot from both sides to tighten it up.
  19. How to Replace a Dial-Lace System in a Hiking Boot, Secure the knot: 19 단계, 이미지 3개 중 1개 How to Replace a Dial-Lace System in a Hiking Boot, Secure the knot: 19 단계, 이미지 3개 중 2개 How to Replace a Dial-Lace System in a Hiking Boot, Secure the knot: 19 단계, 이미지 3개 중 3개
    • Pull the knot once again to fix it.
    • Before cutting, make sure there is a 2-3mm length allowance behind the knot (red lines).
    • Cut the lace in the mentioned length.
  20. How to Replace a Dial-Lace System in a Hiking Boot, Align the lace with the dial: 20 단계, 이미지 3개 중 1개 How to Replace a Dial-Lace System in a Hiking Boot, Align the lace with the dial: 20 단계, 이미지 3개 중 2개 How to Replace a Dial-Lace System in a Hiking Boot, Align the lace with the dial: 20 단계, 이미지 3개 중 3개
    • Align both ends of the lace with the main dial and place it in front of the dial base.
  21. How to Replace a Dial-Lace System in a Hiking Boot, Set the dial in place: 21 단계, 이미지 3개 중 1개 How to Replace a Dial-Lace System in a Hiking Boot, Set the dial in place: 21 단계, 이미지 3개 중 2개 How to Replace a Dial-Lace System in a Hiking Boot, Set the dial in place: 21 단계, 이미지 3개 중 3개
    • Align the edge of the dial (green arrow) with the bottom part (yellow arrow) and make sure it goes inside.
    • Hold the dial with both hands and push it against the "tongue" of the boot until you hear a "click" sound.
  22. How to Replace a Dial-Lace System in a Hiking Boot, Finished and ready!: 22 단계, 이미지 2개 중 1개 How to Replace a Dial-Lace System in a Hiking Boot, Finished and ready!: 22 단계, 이미지 2개 중 2개
    • 🛠️🏆👏 Congratulations! The repair is complete, and you're ready to go!
결론
In need of another repair? Don't worry! Check out our other guides to find quick solutions for your favourite clothing, footwear and equipment!
🚨🛠️🩹 IMPORTANT SAFETY NOTICE:
The repair guides provided on this site are intended to help you repair products on your own. While we have put a lot of care into them, all repair work carries some risk:
  1. Safety Precautions: When repairing your product, take all necessary precautions to ensure your safety. Use appropriate tools and follow the instructions carefully.
  2. Product Condition: Once your product has been repaired, it may not meet original compliance guidelines anymore and could potentially have issues.
  3. Liability: We are not responsible for any damage or injury that may occur during the repair process or as a result of using a repaired product. You, as the repairer, assume all risks and responsibilities associated with the repair.
By using these repair guides, you fully acknowledge and accept the potential risks and responsibilities involved.
작성자
1다른 기여자 명과 함께
Ben Blischke
회원 가입일: 07/19/23
10,230 평판
안내서 66개를 작성함
INTERSPORT INTERSPORT 회원
Community
25 회원들
안내서 169개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 25
지난 30일: 94
전체 시간: 591
