주요 콘텐츠로 건너뛰기
How to Replace a Felt Chair Footing
필요한 것
  1. How to Replace a Felt Chair Footing, Felt Footing: 1 단계, 이미지 1개 중 1개
    • Turn furniture piece upside down so that the leg bottoms are accessible.
  2. How to Replace a Felt Chair Footing: 2 단계, 이미지 3개 중 1개 How to Replace a Felt Chair Footing: 2 단계, 이미지 3개 중 2개 How to Replace a Felt Chair Footing: 2 단계, 이미지 3개 중 3개
    • Using an Exact-o knife or boxcutting blade, carefully cut away the worn out felt footing.
  3. How to Replace a Felt Chair Footing: 3 단계, 이미지 1개 중 1개
    • Cut away any remaining material or residue so that the chair foot is as clear as possible.
    • Depending on the strength of the adhesive that secured the old footing, some of the residue left behind could be tough to remove. In this case, it may be best to keep some rubbing alcohol handy as a solvent to assist in the removal of this residue.
  4. How to Replace a Felt Chair Footing: 4 단계, 이미지 2개 중 1개 How to Replace a Felt Chair Footing: 4 단계, 이미지 2개 중 2개
    • Use pre-cut felt footing replacements to replace the old footing. Press felt footing into center of chair foot firmly.
  5. How to Replace a Felt Chair Footing: 5 단계, 이미지 1개 중 1개
    • Repeat steps 2 and 3 for the remaining three footings.
결론
Now you’re done! With all four footings replaced, you can replace your furniture.
작성자
1다른 기여자 명과 함께
Hunter Golat
회원 가입일: 03/18/21
127 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 17
지난 30일: 65
전체 시간: 2,406
