주요 콘텐츠로 건너뛰기
How to Replace a Guitar Nut
필요한 것
  1. How to Replace a Guitar Nut, Guitar Nut: 1 단계, 이미지 3개 중 1개 How to Replace a Guitar Nut, Guitar Nut: 1 단계, 이미지 3개 중 2개 How to Replace a Guitar Nut, Guitar Nut: 1 단계, 이미지 3개 중 3개
    • Use a micrometer to measure the length, width, and depth of the guitar nut.
    • Use a ruler to measure the string height compared to the first fret.
  2. How to Replace a Guitar Nut: 2 단계, 이미지 1개 중 1개
    • Remove the guitar strings.
    • If your intention is to replace the guitar strings; removing the strings by cutting them will be the most efficient.
    • If you want to keep the current strings; loosening then adjusting the strings will be the most efficient.
  3. How to Replace a Guitar Nut: 3 단계, 이미지 1개 중 1개
    • Use a sharp knife to cut the glue from the edges of the guitar nut.
  4. How to Replace a Guitar Nut: 4 단계, 이미지 2개 중 1개 How to Replace a Guitar Nut: 4 단계, 이미지 2개 중 2개
    • Remove the original nut by striking it with a hammer or mallet.
    • Before knocking the nut out of its slot, make sure it was scored properly.
    • Inspect the location where the nut was removed. Use sandpaper to flatten the location if necessary.
  5. How to Replace a Guitar Nut: 5 단계, 이미지 2개 중 1개 How to Replace a Guitar Nut: 5 단계, 이미지 2개 중 2개
    • Sand the replacement nut, make the measurements identical to the original.
    • Only sand the nut a bit at a time. It's easier to work with a larger nut than a smaller one.
  6. How to Replace a Guitar Nut: 6 단계, 이미지 3개 중 1개 How to Replace a Guitar Nut: 6 단계, 이미지 3개 중 2개 How to Replace a Guitar Nut: 6 단계, 이미지 3개 중 3개
    • Use a pencil to put graphite in the slots of the nut.
  7. How to Replace a Guitar Nut: 7 단계, 이미지 1개 중 1개
    • Place the replacement nut onto the guitar.
    • Restring your guitar or move the strings back into place.
    • Do not glue the nut into place.
    • This step is to verify the measurements of the replacement nut.
  8. How to Replace a Guitar Nut: 8 단계, 이미지 1개 중 1개
    • Verify the string height
    • String height is where precision is key. Make sure it is the EXACT height required.
    • Remove the strings before proceeding to the next step.
  9. How to Replace a Guitar Nut: 9 단계, 이미지 2개 중 1개 How to Replace a Guitar Nut: 9 단계, 이미지 2개 중 2개
    • Using watered-down wood glue, glue the nut onto the guitar.
    • Use a small amount of wood glue.
    • Placing glue on the guitar nut itself is easier than placing glue directly on the guitar.
  10. How to Replace a Guitar Nut: 10 단계, 이미지 1개 중 1개
    • Restring your guitar or move the strings back into place. Tighten the string immediately afterwards to secure the nut.
결론
Make sure the strings are tuned and the nut is in its proper place before claiming to be finished. It is important that the guitar nut becomes glued to the guitar properly. Be certain that the guitar nut is in place before, during, and after tuning the guitar.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Danylo Gula
회원 가입일: 01/10/22
235 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 8
지난 30일: 29
전체 시간: 4,331
