주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
How to Replace a Hoodie Drawstring
필요한 것
    1. How to Replace a Hoodie Drawstring, Hoodie Drawstring: 1 단계, 이미지 2개 중 1개 How to Replace a Hoodie Drawstring, Hoodie Drawstring: 1 단계, 이미지 2개 중 2개
      • If the broken or old drawstring is still in the hood, gently pull it through one of the hood holes.
      댓글 쓰기
    2. How to Replace a Hoodie Drawstring: 2 단계, 이미지 3개 중 1개 How to Replace a Hoodie Drawstring: 2 단계, 이미지 3개 중 2개 How to Replace a Hoodie Drawstring: 2 단계, 이미지 3개 중 3개
      • Wrap a small piece of tape tightly around each end.
      • This step is if you have frayed edges on your drawstring.
      댓글 쓰기
    3. How to Replace a Hoodie Drawstring: 3 단계, 이미지 2개 중 1개 How to Replace a Hoodie Drawstring: 3 단계, 이미지 2개 중 2개
      • Open the safety pin and hook it through one end of the drawstring/shoelace.
      • If you put tape on frayed drawstring, stab the safety pin through the tape.
      • Be careful, your safety pin may be sharp!
      • Close the safety pin securely so it won't open when you put it in your hood.
      댓글 쓰기
    4. How to Replace a Hoodie Drawstring: 4 단계, 이미지 3개 중 1개 How to Replace a Hoodie Drawstring: 4 단계, 이미지 3개 중 2개 How to Replace a Hoodie Drawstring: 4 단계, 이미지 3개 중 3개
      • Insert the safety-pinned end into one drawstring hole.
      • Work it through the hood by bunching and sliding the hoodie fabric along the pin.
      • Keep feeding the pin until it exits the opposite hole.
      댓글 쓰기
    5. How to Replace a Hoodie Drawstring: 5 단계, 이미지 2개 중 1개 How to Replace a Hoodie Drawstring: 5 단계, 이미지 2개 중 2개
      • Pull both ends of the drawstring until they're an even length.
      • Take out your safety pin.
      • Remove you tape (if any was used).
      • Make sure your string slides freely through the hood, and confirm it tightens as it's supposed to.
      댓글 쓰기
    6. How to Replace a Hoodie Drawstring: 6 단계, 이미지 3개 중 1개 How to Replace a Hoodie Drawstring: 6 단계, 이미지 3개 중 2개 How to Replace a Hoodie Drawstring: 6 단계, 이미지 3개 중 3개
      • Tie a small knot on each end to keep the string from slipping back in your hood!
      댓글 쓰기
결론
Replacing a hoodie drawstring is a quick, simple repair that saves your favorite hoodie from the donation pile. You can use this same method for sweatpants, jackets, or gym bags.
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Mia Johnson
회원 가입일: 10/20/25
160 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 8
지난 7일: 27
지난 30일: 137
전체 시간: 1,809
