주요 콘텐츠로 건너뛰기
How to Replace a Jacket Pocket
필요한 것
  1. How to Replace a Jacket Pocket, Pocket: 1 단계, 이미지 2개 중 1개 How to Replace a Jacket Pocket, Pocket: 1 단계, 이미지 2개 중 2개
    • Use the seam cutter to cut and remove the seams attaching the pocket to the jacket.
    • Make sure to cut the seams away from you to ensure that you don't end up stabbing yourself with the seam cutter.
  2. How to Replace a Jacket Pocket: 2 단계, 이미지 2개 중 1개 How to Replace a Jacket Pocket: 2 단계, 이미지 2개 중 2개
    • Measure the pocket length and width using measuring tape and a measuring board.
  3. How to Replace a Jacket Pocket: 3 단계, 이미지 2개 중 1개 How to Replace a Jacket Pocket: 3 단계, 이미지 2개 중 2개
    • Trace the pocket to create a sewing pattern on a piece of paper with a pen.
    • Draw out the length and width of the pocket to the side as a reference for its size.
  4. How to Replace a Jacket Pocket: 4 단계, 이미지 2개 중 1개 How to Replace a Jacket Pocket: 4 단계, 이미지 2개 중 2개
    • Cut out the sewing pattern from the paper using scissors.
    • Leave an extra inch where the pocket opening should be when cutting out the pattern.
  5. How to Replace a Jacket Pocket: 5 단계, 이미지 2개 중 1개 How to Replace a Jacket Pocket: 5 단계, 이미지 2개 중 2개
    • Pin the sewing pattern to the Fat Quarter 100% cotton fabric.
    • Leave a boarder of fabric around the sewing pattern to help make precise cuts.
  6. How to Replace a Jacket Pocket: 6 단계, 이미지 2개 중 1개 How to Replace a Jacket Pocket: 6 단계, 이미지 2개 중 2개
    • Use sewing scissors to cut the fabric along the pattern. These pieces will be sewn together to form the pocket.
    • Repeat the process for the other side of the pocket.
  7. How to Replace a Jacket Pocket: 7 단계, 이미지 2개 중 1개 How to Replace a Jacket Pocket: 7 단계, 이미지 2개 중 2개
    • Pin both fabrics together with their sides aligned exactly in the same direction as the sewing pattern.
    • Make sure that both sides where the pocket opening should be are aligned.
    • Use the sewing pattern as a reference for where the fabric should be laid out and pinned together.
  8. How to Replace a Jacket Pocket: 8 단계, 이미지 2개 중 1개 How to Replace a Jacket Pocket: 8 단계, 이미지 2개 중 2개
    • Sew the fabric together with the Singer Stitch Sew Quick to form the pocket with a 10mm margin of space from the raw cut edges of the fabric.
    • Leave only the pocket opening unstitched by stopping a few centimeters before it, helping to create the pocket fold.
    • Use the pocket that you cut out of the jacket as a reference point for what the stitching should look like.
    • Any standard sewing machine can be used as an alternative to the Singer Stitch Sew Quick device. Another option is hand sewing.
  9. How to Replace a Jacket Pocket: 9 단계, 이미지 2개 중 1개 How to Replace a Jacket Pocket: 9 단계, 이미지 2개 중 2개
    • Use scissors to cutting off any loose thread.
  10. How to Replace a Jacket Pocket: 10 단계, 이미지 3개 중 1개 How to Replace a Jacket Pocket: 10 단계, 이미지 3개 중 2개 How to Replace a Jacket Pocket: 10 단계, 이미지 3개 중 3개
    • Iron out the new pocket with the steam iron.
    • Make sure to place the iron in an upright position when not in use. Pay attention to the fabric you are ironing to avoid burning, and don't touch the face of the iron as it will burn you.
  11. How to Replace a Jacket Pocket: 11 단계, 이미지 2개 중 1개 How to Replace a Jacket Pocket: 11 단계, 이미지 2개 중 2개
    • Insert the new pocket into the jacket.
    • The pocket opening should face the outside, where the previous pocket was ripped out.
    • The stitching and needlework of the pocket should face the outside, leaving the inside of the pocket clean without any noticeable threads when used.
  12. How to Replace a Jacket Pocket: 12 단계, 이미지 3개 중 1개 How to Replace a Jacket Pocket: 12 단계, 이미지 3개 중 2개 How to Replace a Jacket Pocket: 12 단계, 이미지 3개 중 3개
    • Pin the new pocket to the jacket.
    • Flip back the pocket opening flaps to create a fold for the pocket opening and conceal the raw cut edges.
  13. How to Replace a Jacket Pocket: 13 단계, 이미지 3개 중 1개 How to Replace a Jacket Pocket: 13 단계, 이미지 3개 중 2개 How to Replace a Jacket Pocket: 13 단계, 이미지 3개 중 3개
    • Stitch the new pocket onto the jacket using a leather needle and polyester thread.
    • Use a thimble to help push the needle through the fabric and leather.
    • Be careful when the needle is interweaving between the fabrics, as the needle can prick you, causing bleeding.
결승점
작성자
3다른 기여자 명과 함께
Eduardo Martinez
회원 가입일: 08/29/23
217 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 8
지난 7일: 29
지난 30일: 158
전체 시간: 1,859
