주요 콘텐츠로 건너뛰기
How to Replace a Kayak Bungee/Shock Cord
필요한 것
  1. How to Replace a Kayak Bungee/Shock Cord, Find the attachment points: 1 단계, 이미지 1/1
    • Identify the attachment points where the bungee cord is connected. These are usually eyelets, D-rings, or hooks.
  2. How to Replace a Kayak Bungee/Shock Cord, Remove the old bungee cord: 2 단계, 이미지 1/2 How to Replace a Kayak Bungee/Shock Cord, Remove the old bungee cord: 2 단계, 이미지 2/2
    • Carefully cut and pull off the old bungee cord from the attachment point using scissors or a knife.
  3. How to Replace a Kayak Bungee/Shock Cord, Measure and cut the new bungee cord: 3 단계, 이미지 1/3 How to Replace a Kayak Bungee/Shock Cord, Measure and cut the new bungee cord: 3 단계, 이미지 2/3 How to Replace a Kayak Bungee/Shock Cord, Measure and cut the new bungee cord: 3 단계, 이미지 3/3
    • Lay the new bungee cord alongside the old one.
    • Add a few extra inches to your measurement for adjustments and securing the ends.
    • Use scissors or a knife to cut the cord to the required length.
  4. How to Replace a Kayak Bungee/Shock Cord, Attach the new bungee cord: 4 단계, 이미지 1/3 How to Replace a Kayak Bungee/Shock Cord, Attach the new bungee cord: 4 단계, 이미지 2/3 How to Replace a Kayak Bungee/Shock Cord, Attach the new bungee cord: 4 단계, 이미지 3/3
    • Push the cord through either of the attachment points closest to the middle of the kayak.
    • You may use a pen to help guide the cord through if it doesn't go through easily on its own.
    • Tie a simple overhand knot to secure the cord on this end.
    • Thread the cord through the opposite attachment point and then to the next point on the opposite end and repeat - Creating a criss-cross pattern as you thread away from the center of the kayak.
  5. How to Replace a Kayak Bungee/Shock Cord, Test and adjust: 5 단계, 이미지 1/2 How to Replace a Kayak Bungee/Shock Cord, Test and adjust: 5 단계, 이미지 2/2
    • Gently pull on the new bungee cord to make sure it is securely attached and provides the desired tension.
    • You want the cord to be taut but not overly tight.
  6. How to Replace a Kayak Bungee/Shock Cord, Trim any excess cord: 6 단계, 이미지 1/2 How to Replace a Kayak Bungee/Shock Cord, Trim any excess cord: 6 단계, 이미지 2/2
    • Once you are satisfied with the placement and tension of the new bungee cord, tie another overhand knot to secure the bungee on this end of the kayak.
    • Finally, trim any excess length using scissors or a knife.
결론
Follow these steps to remove an old bungee cord and secure a new one to your kayak.
Satumbu Makayi
회원 가입일: 01/15/23
183 평판
안내서 1개 작성함
York University, Team O-19, Woodhouse Winter 2023 York University, Team O-19, Woodhouse Winter 2023 회원
YORK-WOODHOUSE-W23SOG19
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 18
30일 전: 111
전체 시간: 695
