주요 콘텐츠로 건너뛰기
How to Replace a Kayak Bungee/Shock Cord
필요한 것
  1. How to Replace a Kayak Bungee/Shock Cord, Find the attachment points: 1 단계, 이미지 1개 중 1개
    • Identify the attachment points where the bungee cord is connected. These are usually eyelets, D-rings, or hooks.
  2. How to Replace a Kayak Bungee/Shock Cord, Remove the old bungee cord: 2 단계, 이미지 2개 중 1개 How to Replace a Kayak Bungee/Shock Cord, Remove the old bungee cord: 2 단계, 이미지 2개 중 2개
    • Carefully cut and pull off the old bungee cord from the attachment point using scissors or a knife.
  3. How to Replace a Kayak Bungee/Shock Cord, Measure and cut the new bungee cord: 3 단계, 이미지 3개 중 1개 How to Replace a Kayak Bungee/Shock Cord, Measure and cut the new bungee cord: 3 단계, 이미지 3개 중 2개 How to Replace a Kayak Bungee/Shock Cord, Measure and cut the new bungee cord: 3 단계, 이미지 3개 중 3개
    • Lay the new bungee cord alongside the old one.
    • Add a few extra inches to your measurement for adjustments and securing the ends.
    • Use scissors or a knife to cut the cord to the required length.
  4. How to Replace a Kayak Bungee/Shock Cord, Attach the new bungee cord: 4 단계, 이미지 3개 중 1개 How to Replace a Kayak Bungee/Shock Cord, Attach the new bungee cord: 4 단계, 이미지 3개 중 2개 How to Replace a Kayak Bungee/Shock Cord, Attach the new bungee cord: 4 단계, 이미지 3개 중 3개
    • Push the cord through either of the attachment points closest to the middle of the kayak.
    • You may use a pen to help guide the cord through if it doesn't go through easily on its own.
    • Tie a simple overhand knot to secure the cord on this end.
    • Thread the cord through the opposite attachment point and then to the next point on the opposite end and repeat - Creating a criss-cross pattern as you thread away from the center of the kayak.
  5. How to Replace a Kayak Bungee/Shock Cord, Test and adjust: 5 단계, 이미지 2개 중 1개 How to Replace a Kayak Bungee/Shock Cord, Test and adjust: 5 단계, 이미지 2개 중 2개
    • Gently pull on the new bungee cord to make sure it is securely attached and provides the desired tension.
    • You want the cord to be taut but not overly tight.
  6. How to Replace a Kayak Bungee/Shock Cord, Trim any excess cord: 6 단계, 이미지 2개 중 1개 How to Replace a Kayak Bungee/Shock Cord, Trim any excess cord: 6 단계, 이미지 2개 중 2개
    • Once you are satisfied with the placement and tension of the new bungee cord, tie another overhand knot to secure the bungee on this end of the kayak.
    • Finally, trim any excess length using scissors or a knife.
결론
Follow these steps to remove an old bungee cord and secure a new one to your kayak.
작성자
3다른 기여자 명과 함께
Satumbu Makayi
회원 가입일: 01/15/23
183 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 28
전체 시간: 1,686
