주요 콘텐츠로 건너뛰기
How to Replace a Leaking Set Screw Tub Spout
필요한 것
  1. How to Replace a Leaking Set Screw Tub Spout, Set Screw Tub Spout: 1 단계, 이미지 2개 중 1개 How to Replace a Leaking Set Screw Tub Spout, Set Screw Tub Spout: 1 단계, 이미지 2개 중 2개
    • Cover the shower drain with a plug or a piece of cloth to prevent the screw from falling in.
    • Make sure the water is turned off.
  2. How to Replace a Leaking Set Screw Tub Spout: 2 단계, 이미지 3개 중 1개 How to Replace a Leaking Set Screw Tub Spout: 2 단계, 이미지 3개 중 2개 How to Replace a Leaking Set Screw Tub Spout: 2 단계, 이미지 3개 중 3개
    • Using an 5/32" Allen key, loosen the screw located under the spout.
    • You should not remove the screw. But instead, untighten the screw until it's loose.
  3. How to Replace a Leaking Set Screw Tub Spout: 3 단계, 이미지 3개 중 1개 How to Replace a Leaking Set Screw Tub Spout: 3 단계, 이미지 3개 중 2개 How to Replace a Leaking Set Screw Tub Spout: 3 단계, 이미지 3개 중 3개
    • Gently pull out the spout using your hand and set it aside somewhere.
    • Protip: Wiggle the spout side to side to help pull it out.
  4. How to Replace a Leaking Set Screw Tub Spout: 4 단계, 이미지 3개 중 1개 How to Replace a Leaking Set Screw Tub Spout: 4 단계, 이미지 3개 중 2개 How to Replace a Leaking Set Screw Tub Spout: 4 단계, 이미지 3개 중 3개
    • Using sandpaper or a sponge, gently rub and clean the pipe.
    • This allows for the new set screw tub spout to easily slip on.
    • Once you have finished cleaning the pipe, wipe off the dust with a piece of cloth or paper towel.
  5. How to Replace a Leaking Set Screw Tub Spout: 5 단계, 이미지 3개 중 1개 How to Replace a Leaking Set Screw Tub Spout: 5 단계, 이미지 3개 중 2개 How to Replace a Leaking Set Screw Tub Spout: 5 단계, 이미지 3개 중 3개
    • Take your new set screw tub spout and slide it in gently into the wall.
    • Protip: Wiggle the spout side to side to help push it back in.
  6. How to Replace a Leaking Set Screw Tub Spout: 6 단계, 이미지 3개 중 1개 How to Replace a Leaking Set Screw Tub Spout: 6 단계, 이미지 3개 중 2개 How to Replace a Leaking Set Screw Tub Spout: 6 단계, 이미지 3개 중 3개
    • Retighten the set screw using the 5/32" Allen key.
결론
Turn on the bath water to ensure the set screw tub spout has no leaks and is working as intended.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Hadjie Figueroa
회원 가입일: 01/27/21
145 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 12
지난 30일: 51
전체 시간: 4,555
