주요 콘텐츠로 건너뛰기
How to Replace a Screen Protector on an iPhone 12
필요한 것
  1. How to Replace a Screen Protector on an iPhone 12, Screen Protector: 1 단계, 이미지 1/3 How to Replace a Screen Protector on an iPhone 12, Screen Protector: 1 단계, 이미지 2/3 How to Replace a Screen Protector on an iPhone 12, Screen Protector: 1 단계, 이미지 3/3
    • If you already have a pre-existing screen protector, you will gently peel of your existing screen protector from the top of you iPhone.
    • If any small pieces of the screen protector are still attached to the phone, genlty peel the pieces off until no more pieces remain.
    • When the screen protector and the pieces are removed, you can dispose of it immediately or set it aside for disposal.
  2. How to Replace a Screen Protector on an iPhone 12: 2 단계, 이미지 1/3 How to Replace a Screen Protector on an iPhone 12: 2 단계, 이미지 2/3 How to Replace a Screen Protector on an iPhone 12: 2 단계, 이미지 3/3
    • Grab the wet cloth from the pack and wipe the screen of the iPhone in order to remove any stain or mark left behind.
  3. How to Replace a Screen Protector on an iPhone 12: 3 단계, 이미지 1/2 How to Replace a Screen Protector on an iPhone 12: 3 단계, 이미지 2/2
    • With the LCD cloth, wipe and dry the screen of the phone to remove any small debris or dust.
  4. How to Replace a Screen Protector on an iPhone 12: 4 단계, 이미지 1/3 How to Replace a Screen Protector on an iPhone 12: 4 단계, 이미지 2/3 How to Replace a Screen Protector on an iPhone 12: 4 단계, 이미지 3/3
    • Grab the dust sticker and apply it all around on the screen multiple times, until you covered all areas of the iPhone display.
  5. How to Replace a Screen Protector on an iPhone 12: 5 단계, 이미지 1/3 How to Replace a Screen Protector on an iPhone 12: 5 단계, 이미지 2/3 How to Replace a Screen Protector on an iPhone 12: 5 단계, 이미지 3/3
    • Grab the screen protector and remove the plastic that's attached to the sticky part of the screen protector.
    • Align the new screen protector to the iPhone without touching the sticky part.
    • Press down on the screen protector from the top of the iPhone until you reach the bottom.
  6. How to Replace a Screen Protector on an iPhone 12: 6 단계, 이미지 1/3 How to Replace a Screen Protector on an iPhone 12: 6 단계, 이미지 2/3 How to Replace a Screen Protector on an iPhone 12: 6 단계, 이미지 3/3
    • With the new screen protector on the phone, use the anti-bubble card to prevent bubbles from staying in between the iPhone and the screen protector.
    • Push the bubbles towards the edge of the iPhone until you see no more on the screen.
  7. How to Replace a Screen Protector on an iPhone 12: 7 단계, 이미지 1/1
    • With the bubbles removed from the screen, the new screen protector for the iPhone 12 is now installed.
    • Dispose of any waste left after the installation.
결론
reveleszacatecas5
회원 가입일: 10/24/23
145 평판
안내서 1개 작성함
CSU Los Angeles, Team 8-3, Ribeiro Fall 2023 CSU Los Angeles, Team 8-3, Ribeiro Fall 2023 회원
CSULA-RIBEIRO-F23S8G3
3 회원들
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 9
7일 전: 44
30일 전: 255
전체 시간: 1,196
