주요 콘텐츠로 건너뛰기
How to Replace a Shoe Eyelet
필요한 것
  1. How to Replace a Shoe Eyelet, Choose the right replacement eyelet: 1 단계, 이미지 3개 중 1개 How to Replace a Shoe Eyelet, Choose the right replacement eyelet: 1 단계, 이미지 3개 중 2개 How to Replace a Shoe Eyelet, Choose the right replacement eyelet: 1 단계, 이미지 3개 중 3개
    • Important: The first step of the repair - the preparation - is very important! Spend some time to do this carefully, and the next steps will fly by.
    • First, pull out the lace from the damaged or lost eyelet hole.
    • If the old eyelet is only damaged, but still attached, it will need removing:
    • Use a pair of pliers to gently grip the damaged eyelet from the outside, and gently turn and rotate it simultaneously. With some effort, you should be able to separate the front half of the eyelet from the back half. If needed, take a second pair of pliers to grip the inside, while you pull/turn the outside half away.
    • A successful removal of the eyelet is when the front half separates from the back half, and both are removed without damaging the backing fabric.
    • Once the eyelet is removed, take note of the inner hole size (inner diameter) and the outer metal size (outer diameter).
    • Use these sizes when purchasing a new eyelet. We recommend purchasing an eyelet replacement kit, which includes the "punch" tools too (see photo).
  2. How to Replace a Shoe Eyelet, Prepare the Shoe and the Tools: 2 단계, 이미지 3개 중 1개 How to Replace a Shoe Eyelet, Prepare the Shoe and the Tools: 2 단계, 이미지 3개 중 2개 How to Replace a Shoe Eyelet, Prepare the Shoe and the Tools: 2 단계, 이미지 3개 중 3개
    • Place the shoe on a clean and stable surface.
    • Prepare the eyelet, the hammer and the "punch" tool.
    • Note: Take time to understand the punch tool and match the appropriate halves of the new eyelet to the matching sides of the punch tool. One half is for the inside; the other is for the outside.
    • On the sample shown here, the yellow arrow shows the inside half; and the green arrow shows the outside half.
    • Insert the replacement eyelet to the lace hole using your fingers. Take care to insert the outside half from the outside, and the inside half from the inside.
  3. How to Replace a Shoe Eyelet, Install the New Eyelet: 3 단계, 이미지 3개 중 1개 How to Replace a Shoe Eyelet, Install the New Eyelet: 3 단계, 이미지 3개 중 2개 How to Replace a Shoe Eyelet, Install the New Eyelet: 3 단계, 이미지 3개 중 3개
    • Tip: For the next step, we advise protecting your work surface during hammering. A wooden/plastic chopping board, or an old piece of wood will work well for this.
    • Position the frontside half of the eyelet through the eyelet hole in the shoe. It should remain relatively well in place.
    • Next, position the backside eyelet half onto the punch tool, and carefully lift the tool to the eyelet hole.
    • This can be fiddly! Take your time and if the eyelet halves fall out, take care to re-install them back onto the correct sides.
    • Close the punch tool, to keep the two halves securely together. Make sure this is in a comfortable orientation, to allow hammering onto the wooden block in the next step.
  4. How to Replace a Shoe Eyelet, Check and Reinsert the Lace: 4 단계, 이미지 3개 중 1개 How to Replace a Shoe Eyelet, Check and Reinsert the Lace: 4 단계, 이미지 3개 중 2개 How to Replace a Shoe Eyelet, Check and Reinsert the Lace: 4 단계, 이미지 3개 중 3개
    • Take care: Check that the eyelet is located in the right place and that both metal rings are closely connected.
    • Start hammering! The goal is to connect the two halves together securely, but it isn't normally needed to apply lots of force. Use a soft tapping motion with the hammer and after a few taps the two halves should be connected.
    • Gently open the punch tool and check whether the two halves have connected correctly. If not: close the tool and tap a few more times, until completed.
    • A correctly installed eyelet will be secure with no loose parts and no defects. Check the other eyelets for reference.
    • In case of defects, return to the beginning of this guide and remove the eyelet to try again.
  5. How to Replace a Shoe Eyelet, Finished and ready!: 5 단계, 이미지 2개 중 1개 How to Replace a Shoe Eyelet, Finished and ready!: 5 단계, 이미지 2개 중 2개
    • 🛠️🏆👏 Congratulations! The repair is complete, and you're ready to go!
    • Now simply re-lace the shoe and start wearing it again.
결론
In need of another repair? Don't worry! Check out our other guides to find quick solutions for your favourite clothing, footwear and equipment!
🚨🛠️🩹 IMPORTANT SAFETY NOTICE:
The repair guides provided on this site are intended to help you repair products on your own. While we have put a lot of care into them, all repair work carries some risk:
  1. Safety Precautions: When repairing your product, take all necessary precautions to ensure your safety. Use appropriate tools and follow the instructions carefully.
  2. Product Condition: Once your product has been repaired, it may not meet original compliance guidelines anymore and could potentially have issues.
  3. Liability: We are not responsible for any damage or injury that may occur during the repair process or as a result of using a repaired product. You, as the repairer, assume all risks and responsibilities associated with the repair.
By using these repair guides, you fully acknowledge and accept the potential risks and responsibilities involved.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Ben Blischke
회원 가입일: 07/19/23
10,230 평판
안내서 66개를 작성함
INTERSPORT INTERSPORT 회원
Community
25 회원들
안내서 169개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 6
지난 7일: 45
지난 30일: 259
전체 시간: 3,695
