주요 콘텐츠로 건너뛰기
How to Replace a Skateboard Deck
필요한 것
  1. How to Replace a Skateboard Deck, Deck: 1 단계, 이미지 1개 중 1개
    • Use the 3/8" socket to take off the nut
    • Use the phillips side to hold the screw in place.
    • Remove the nut
    • Repeat for all four nuts on the truck
    • Repeat for the second truck
  2. How to Replace a Skateboard Deck: 2 단계, 이미지 2개 중 1개 How to Replace a Skateboard Deck: 2 단계, 이미지 2개 중 2개
    • Remove both trucks from the board
    • Remove all 8 screws
  3. How to Replace a Skateboard Deck: 3 단계, 이미지 3개 중 1개 How to Replace a Skateboard Deck: 3 단계, 이미지 3개 중 2개 How to Replace a Skateboard Deck: 3 단계, 이미지 3개 중 3개
    • Line up the grip with the board
    • Ensure it covers the entirety of the board and hangs over the edge
    • Peel the back off at one end enough to reveal the sticky side.
    • Expose about four inches
    • Attach the peeled side to one end of the board
    • Press the grip onto the board slowly and work your way across the board
    • Ensure that there is no air bubbles forming when applying the grip
  4. How to Replace a Skateboard Deck: 4 단계, 이미지 2개 중 1개 How to Replace a Skateboard Deck: 4 단계, 이미지 2개 중 2개
    • Use the phillips head screwdriver to trace the edge of the board
    • Ensure it can be seen all the way around the board
  5. How to Replace a Skateboard Deck: 5 단계, 이미지 1개 중 1개
    • Trim the grip along the trace you made with the box cutter
    • Use long and smooth motions for straight trims
    • Trim up the jagged edges left on the grip on the edge of the board
  6. How to Replace a Skateboard Deck: 6 단계, 이미지 1개 중 1개
    • Sand the edges with the left over grip
    • This is to ensure the grip fully applies to the board
  7. How to Replace a Skateboard Deck: 7 단계, 이미지 2개 중 1개 How to Replace a Skateboard Deck: 7 단계, 이미지 2개 중 2개
    • Poke a hole with the screw from the bottom of the deck
    • Remove the screw
    • Insert it through the top on the deck
    • Repeat for all 4 holes
    • Repeat on the opposite side with the other truck
  8. How to Replace a Skateboard Deck: 8 단계, 이미지 3개 중 1개 How to Replace a Skateboard Deck: 8 단계, 이미지 3개 중 2개 How to Replace a Skateboard Deck: 8 단계, 이미지 3개 중 3개
    • Use the 3/8" socket to screw on the nut
    • The hangar should face outwards
    • Tighten them until they're snug
    • Overtightening can damage the deck
결승점
작성자
1다른 기여자 명과 함께
Dylan Norris
회원 가입일: 10/06/22
157 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 8
지난 30일: 23
전체 시간: 973
