주요 콘텐츠로 건너뛰기
How to Replace a Standard Door Lock
필요한 것
  1. How to Replace a Standard Door Lock, Standard Door Lock: 1 단계, 이미지 2개 중 1개 How to Replace a Standard Door Lock, Standard Door Lock: 1 단계, 이미지 2개 중 2개
    • Place a piece of tape on both sides of the lock to ensure it doesn’t fall on the floor once unscrewed.
    • Make sure enough tape is placed on the lock as the current door lock may be heavier than expected and could fall off once unscrewed.
    • Ensure the surrounding area is free of any debris or dust that may interfere with the installation.
    • Place a towel, cloth, or even a container/bucket on the area below the door in case the lock falls to ensure no damage is done to the floor or the surrounding area.
  2. How to Replace a Standard Door Lock: 2 단계, 이미지 1개 중 1개
    • Use your Phillips #2 screwdriver to remove the two 70 mm pan head screws on the side that holds the lock in place.
    • Hold one side of the lock for extra stability if required.
  3. How to Replace a Standard Door Lock: 3 단계, 이미지 2개 중 1개 How to Replace a Standard Door Lock: 3 단계, 이미지 2개 중 2개
    • Remove the tape on both sides of the lock carefully.
  4. How to Replace a Standard Door Lock: 4 단계, 이미지 3개 중 1개 How to Replace a Standard Door Lock: 4 단계, 이미지 3개 중 2개 How to Replace a Standard Door Lock: 4 단계, 이미지 3개 중 3개
    • Align your new lock with the given holes on the door.
  5. How to Replace a Standard Door Lock: 5 단계, 이미지 2개 중 1개 How to Replace a Standard Door Lock: 5 단계, 이미지 2개 중 2개
    • Place a piece of tape on both sides of the new lock to ensure the lock does not move when placing the screws.
    • Make sure the enough tape is placed on the lock as it may fall off depending on the weight of the door lock.
    • Place a cloth or container underneath the lock in case it falls off to ensure no damage is done to the floor or the surrounding area.
  6. How to Replace a Standard Door Lock: 6 단계, 이미지 3개 중 1개 How to Replace a Standard Door Lock: 6 단계, 이미지 3개 중 2개 How to Replace a Standard Door Lock: 6 단계, 이미지 3개 중 3개
    • Place the 70 mm pan head screws in the given holes and use your Phillips #2 screwdriver to screw them in accordingly.
결론
Congratulations! You have successfully installed your new door lock!
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Sanjeeve Krishnamoorthy
회원 가입일: 01/19/21
133 평판
안내서 1개를 작성함
1가이드 댓글
Hi Sanjeeve, this is a great guide its really helpful with the photos you have included here to really walk you through it. I am going to change my door lock to another type and found this article with other types of door locks helpful for that.
Terry - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 8
지난 30일: 23
전체 시간: 1,007
