주요 콘텐츠로 건너뛰기
How to Replace a Tail Light for a 2011-2015 Ford Explorer
필요한 것
  1. How to Replace a Tail Light for a 2011-2015 Ford Explorer, Tail Light Bulbs: 1 단계, 이미지 1/2 How to Replace a Tail Light for a 2011-2015 Ford Explorer, Tail Light Bulbs: 1 단계, 이미지 2/2
    • Lift and open the rear cargo door.
  2. How to Replace a Tail Light for a 2011-2015 Ford Explorer: 2 단계, 이미지 1/1
    • Locate the two plastic screw covers that are adjacent to the rear light covers.
  3. How to Replace a Tail Light for a 2011-2015 Ford Explorer: 3 단계, 이미지 1/1
    • Using a flathead screwdriver, pry out both plastic screw covers.
  4. How to Replace a Tail Light for a 2011-2015 Ford Explorer: 4 단계, 이미지 1/1
    • Once covers are removed, there will be an 8 mm hex head screw located beneath each cover.
  5. How to Replace a Tail Light for a 2011-2015 Ford Explorer: 5 단계, 이미지 1/1
    • Using an 8 mm Deep Socket Wrench, remove both of the 20 mm (length) hex-head screws.
  6. How to Replace a Tail Light for a 2011-2015 Ford Explorer: 6 단계, 이미지 1/2 How to Replace a Tail Light for a 2011-2015 Ford Explorer: 6 단계, 이미지 2/2
    • Gently pull the tail light cover from the car.
    • You may have to gently play with the cover by moving it back and forth in order to pry it loose form the car.
  7. How to Replace a Tail Light for a 2011-2015 Ford Explorer: 7 단계, 이미지 1/1
    • Once removed, the bulb sockets will be located on the inside portion of the tail light cover.
  8. How to Replace a Tail Light for a 2011-2015 Ford Explorer: 8 단계, 이미지 1/1
    • Turn the bulb socket about one quarter turn in a counterclockwise direction.
    • After it is turned, gently pull and remove the bulb socket from the tail light cover.
  9. How to Replace a Tail Light for a 2011-2015 Ford Explorer: 9 단계, 이미지 1/1
    • Gently remove the bulb from the bulb socket.
  10. How to Replace a Tail Light for a 2011-2015 Ford Explorer: 10 단계, 이미지 1/1
    • Gently place the new bulb in the bulb socket.
결론
다른 8명이 해당 안내서를 완성하였습니다.
Michael Lynch
회원 가입일: 09/29/15
317 평판
안내서 1개 작성함
Cal Poly, Team 14-4, Green Fall 2015 Cal Poly, Team 14-4, Green Fall 2015 회원
CPSU-GREEN-F15S14G4
5 회원들
안내서 16개 작성하였습니다
댓글 한 개
That's not the tail lights that is the turn signal and back up lights.
Djay Glass - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 16
30일 전: 85
전체 시간: 21,839
