주요 콘텐츠로 건너뛰기
How to Replace a Tail Light on a Nissan Pathfinder
필요한 것
  1. How to Replace a Tail Light on a Nissan Pathfinder, Tail Light on Nissan Pathfinder: 1 단계, 이미지 3개 중 1개 How to Replace a Tail Light on a Nissan Pathfinder, Tail Light on Nissan Pathfinder: 1 단계, 이미지 3개 중 2개 How to Replace a Tail Light on a Nissan Pathfinder, Tail Light on Nissan Pathfinder: 1 단계, 이미지 3개 중 3개
    • Insert a flathead screwdriver into the top of the trim cover and gently pry it towards you.
    • Repeat the above step to the bottom of the trim cover.
    • Pull the trim cover off.
    • Set the trim cover aside in a safe place.
  2. How to Replace a Tail Light on a Nissan Pathfinder: 2 단계, 이미지 3개 중 1개 How to Replace a Tail Light on a Nissan Pathfinder: 2 단계, 이미지 3개 중 2개 How to Replace a Tail Light on a Nissan Pathfinder: 2 단계, 이미지 3개 중 3개
    • Remove the two bolts using a 10mm socket and a 1/4" ratchet wrench.
    • Place the wrench on the top bolt and turn counterclockwise until the bolt is entirely off.
    • Repeat the above step to the bottom bolt.
    • Set bolts aside in a safe place.
  3. How to Replace a Tail Light on a Nissan Pathfinder: 3 단계, 이미지 3개 중 1개 How to Replace a Tail Light on a Nissan Pathfinder: 3 단계, 이미지 3개 중 2개 How to Replace a Tail Light on a Nissan Pathfinder: 3 단계, 이미지 3개 중 3개
    • Gently pull on the tail light housing to disengage the friction fasteners from their grommets.
    • Once all fasteners have been disengaged, pull the tail light housing out.
  4. How to Replace a Tail Light on a Nissan Pathfinder: 4 단계, 이미지 3개 중 1개 How to Replace a Tail Light on a Nissan Pathfinder: 4 단계, 이미지 3개 중 2개 How to Replace a Tail Light on a Nissan Pathfinder: 4 단계, 이미지 3개 중 3개
    • Rotate the grey plastic bulb socket 1/4 and turn counterclockwise before pulling it straight out of the housing.
    • Pull the old light bulb straight out of the socket.
  5. How to Replace a Tail Light on a Nissan Pathfinder: 5 단계, 이미지 3개 중 1개 How to Replace a Tail Light on a Nissan Pathfinder: 5 단계, 이미지 3개 중 2개 How to Replace a Tail Light on a Nissan Pathfinder: 5 단계, 이미지 3개 중 3개
    • Push a new 7443 bulb into the socket.
    • Re-insert the socket into the housing and rotate it 1/4 turn clockwise to secure it in place.
  6. How to Replace a Tail Light on a Nissan Pathfinder: 6 단계, 이미지 2개 중 1개 How to Replace a Tail Light on a Nissan Pathfinder: 6 단계, 이미지 2개 중 2개
    • Line up the two metal pegs near the outer edge of the housing with their corresponding plastic grommets on the rear corner of the SUV.
    • Carefully push the tail light housing back into place.
  7. How to Replace a Tail Light on a Nissan Pathfinder: 7 단계, 이미지 2개 중 1개 How to Replace a Tail Light on a Nissan Pathfinder: 7 단계, 이미지 2개 중 2개
    • Spin in the two bolts a few turns by hand to prevent them from falling.
  8. How to Replace a Tail Light on a Nissan Pathfinder: 8 단계, 이미지 2개 중 1개 How to Replace a Tail Light on a Nissan Pathfinder: 8 단계, 이미지 2개 중 2개
    • Tighten the two bolts by turning them clockwise with the 10mm socket and a 1/4" drive ratchet until tight.
    • Avoid over-tightening the bolts to prevent from cracking the plastic inner edge of the tail light housing.
  9. How to Replace a Tail Light on a Nissan Pathfinder: 9 단계, 이미지 3개 중 1개 How to Replace a Tail Light on a Nissan Pathfinder: 9 단계, 이미지 3개 중 2개 How to Replace a Tail Light on a Nissan Pathfinder: 9 단계, 이미지 3개 중 3개
    • Line up the trim cover and push it back into place over the inner edge of the tail light housing.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Leslie Salazar
회원 가입일: 09/22/23
196 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 24
지난 30일: 88
전체 시간: 1,169
